05-13-2013, 03:57 | #1 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1910982 Status: Offline Thanks Meter: 0 | help me ! 1. Make sure to 100% remove all boxes (except ATF) from your USB PORT... 2. In Device Manager, make sure the Driver Version of your USB to Serial Converter A and B are year 2009 or above versions. If it is below year 2009, then you need to download this: http://www.ftdichip.com/Drivers/CDM/CDM20808.zip and update the drivers for USB to Serial Converter A and B *** Restart PC after updating the drivers... 3. Go here --- > C:\AdvanceBox Turbo Flasher\Driver\MProg 3.5 Release\ 4. Run "Mprog.exe" 5. Click "File" ---> "Open" then select "new abox turboflasher.ept" file 6. Click "Device" ---> "Erase" 7. Click "Device" ---> "Program" After successfully Programming, close MPROG software and disconnect ATF Box from PC for 5 seconds... Then reconnect it. It will ask for drivers,,, select the correct one here: C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS |
