02-04-2014, 18:20 | #1 (permalink) |
Insane Poster Join Date: Jul 2009 Location: T-Mobile Computer Age: 42
Member: 1070313 Status: Offline Sonork: 100.1593127 Thanks Meter: 16 | Help Me To Boot Repair Nokia Lumia 900.1 (RM-808) - [SOLVED] Please Help Me To Boot Repair Nokia Lumia 900.1 (RM-808) My Phone is hang on lumia logo & auto restart, now im try to repair boot but get this error My ATF is JTAG Activated ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC IS NOT Ready! (CMD1) Try to Adjust VCCIO Voltage CMD1 Reply: 0xFF7FFFFD BOOT Images Written Successfully! Total Elapsed Time 00:00:30 |
02-04-2014, 19:21 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, at first try to full flash phone, if problem remain, than it could be MODEM problem and it can be repaired via ATF JTAG |
02-05-2014, 10:17 | #6 (permalink) |
Member: 1070313 Status: Offline Sonork: 100.1593127 Thanks Meter: 16 | Now This Problem ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V CID : FE014E4D4D43313647270C7B02C0 CSD : D04F01320F5903FFFFFFFFFF8A400001 eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED Lumia 900 Detected eMMC Device Information Manufacturer ID: FE Device Type : Embedded BGA Application ID : 4E Product Name : MMC16G Product Rev : 2.7 Product SN : 0C7B02C0 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Writing MBR... Write Success! Writing DBL... ERROR: Block Write Failed at 0x00000002 Check your Test Point Soldering! ERROR: WRITE FAILED! Total Elapsed Time 00:00:09 N.B: I Checked Soldering Several Times Its Perfect Last edited by Ubxije; 02-05-2014 at 10:26. |
02-05-2014, 10:43 | #7 (permalink) |
Member: 1070313 Status: Offline Sonork: 100.1593127 Thanks Meter: 16 | Finally Problem Solved, Done -- Successfully! ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V CID : FE014E4D4D43313647270C7B02C0 CSD : D04F01320F5903FFFFFFFFFF8A400001 eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED Lumia 900 Detected eMMC Device Information Manufacturer ID: FE Device Type : Embedded BGA Application ID : 4E Product Name : MMC16G Product Rev : 2.7 Product SN : 0C7B02C0 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Writing MBR... Write Success! Writing DBL... Write Success! BOOT Images Written Successfully! Total Elapsed Time 00:00:40 |
The Following User Says Thank You to Ubxije For This Useful Post: |
