12-16-2013, 18:58 | #1 (permalink) |
No Life Poster Join Date: Nov 2006
Member: 384641 Status: Offline Thanks Meter: 31 | Help me please 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! Try to Adjust VCCIO Voltage CMD1 Reply: 0x5E5E5E5E please help me for solutions this problem thankl you |
12-17-2013, 07:05 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Here is the solution ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! Try to Adjust VCCIO Voltage CMD1 Reply: 0x5E5E5E5E Br - srinibas |
