09-02-2014, 08:42 | #1 (permalink) |
Registered User Join Date: Aug 2006 Location: keep learning until the end
Member: 333891 Status: Offline Thanks Meter: 21 | help . nokia 625 rm-943 dead after flashing - (SOLVED) then try to flash with atf Code: 17:01:40 : Boot Flash Mode Successful... 17:01:40 : Buffers Flushed OK... 17:01:40 : 17:01:40 : Phone Info Query Start... 17:01:41 : Blocks Returned: 0x00 Blocks 17:01:41 : Checking SD Card Size... 17:01:41 : Card Size: 0x00000000 17:01:41 : Checking Platform Security Status... 17:01:41 : Platform Secure Boot Status: Not Active 17:01:41 : Secure FFU EFUSE Status: Not Active 17:01:41 : Debug Status: Not Active 17:01:41 : RDC Status: Not Active 17:01:41 : Authentication Status: Not Active 17:01:41 : UEFI Secure Boot Status: Not Active 17:01:41 : Checking Secure FFU Mode... 17:01:41 : Secure FFU Mode : NONE 17:01:41 : Query Flash App Information... 17:01:41 : Flash App Information: 17:01:41 : Flash App Protocol Version: 0.0 17:01:41 : Flash App Implementation Version: 0.0 17:01:41 : Query ROOT KEY HASH... 17:01:41 : ROOT_KEY_HASH: 17:01:41 : 17:01:41 : Sending Image Signatures... 17:01:41 : ERROR: Flash Signature Block REJECTED! 17:01:41 : ERROR: Flashing Failed! 17:06:11 : ERROR: Select Correct Phone Type! 17:06:11 : 17:06:11 : Total Elapsed Time 00:00:00 17:06:28 : 17:06:59 : ERROR: Invalid Reply Detected... 0xA0 can solved without jtag? but i not active atf jtag. try with rixx jtag resurrection complete but still same. |
09-02-2014, 10:24 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ivan rose ATF DOES NOT even detect your phone at all... QDLOADER 9008 is dead BOOT. You need to repair it via JTAG... or It could possibly be just extremely LOW BATTERY. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
09-04-2014, 07:02 | #4 (permalink) |
Member: 333891 Status: Offline Thanks Meter: 21 | report after activate jtag.. falshing with atf Code: Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ====================================================== Windows Phone 8 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ====================================================== Process Cancelled... Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 358359050165040 Version: 1.1.1.3 Product Code: 059T4N7 Module Code: 0205641 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P6083.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011C00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.28 Query ROOT KEY HASH... ROOT_KEY_HASH: 3676E9A0045A7EF8417B8E0E0677CED5F9DD47799826AEAE75F7081818DE716E Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:02:41 thx atf |
