09-11-2012, 10:52 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | Help nokia c6 hangs on nokia logo after flash!!!! HERE IS THE LOG WITH ATF: Number of Image Files: 3 Processing Image File : RM-612_42.0.004_prd.core.C00 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 489 Entry Point: 0x2AD269 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-612_42.0.004_prd.rofs2.V08 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 130 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-612_42.0.004_uda_1_001.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 228 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 07D00004 ID DWORD 1 : 62980252 ID DWORD 2 : B01CE127 ID DWORD 3 : A3FA702F ID DWORD 4 : 85D9549E 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0050 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 20000000 (512 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_XSR15_a lg.fg SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) SendCodeStart_NewProtocol SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 54 04 01 00 00 00 A5 VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 505A5C85580A6322C103BFE4E67B73EF478E791C START READING RPL DATA IMEI: 356994044618332 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... EMPTY NPC CERTIFICATE INFORMATION (CMT): IMEI : 365990444163823 PRODUCT CODE : 0597688 WLAN ID : A8:E0:18:B8:79:E1 BLUETOOTH ID : A8:E0:18:B8:04:B1 PUBLIC_ID : 07D0000462980252B01CE127A3FA702F85D9549E PAPUB_KEYS_HASH: 505A5C85580A6322C103BFE4E67B73EF478E791C CCC CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 0597688 HWC CERTIFICATE INFORMATION (CMT): PUBLIC_ID : 07D0000462980252B01CE127A3FA702F85D9549E PRODUCT CODE : 0597688 RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356994044618332\3569940446183 32_113051.rpl ImagePath: D:\Products\RM-612\42.0.4\ ImageFilename: RM-612_42.0.004_prd.core.C00 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00080000 Size : 019A0000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 01A20000 Size : 0B980000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0D3C0000 Size : 11BC0000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 1F140000 Size : 003C0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200080000019A0000000000040000000201A200000B9800 0000000008000000010D3C000011BC00000000000A00000001 1F140000003C0000EF PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x57 (87) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-00082FFF 1 : 00083400-003FFFFF 2 : 00800000-00D5FFFF 3 : 00D60000-0D39FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5004120B0003000004000000082FFF120B0003000008340000 3FFFFF120B0003000080000000D5FFFF120B00030000D60000 0D39FFFF5B FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000000000 0002000000640000000B000000020000000100000000000000 0033 Successfully Erased... Total blocks to write : 489 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [505A5C85580A6322C103BFE4E67B73EF478E791C] >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ImagePath: D:\Products\RM-612\42.0.4\ ImageFilename: RM-612_42.0.004_prd.rofs2.V08 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 094A0000-0C49FFFF ERASE_REQUEST_BB5 : 5001120B000300094A00000C49FFFF38 Successfully Erased... Total blocks to write : 130 >> CMT Rootkey Hash CERT : SOS+ROFS2 ImagePath: D:\Products\RM-612\42.0.4\ ImageFilename: RM-612_42.0.004_uda_1_001.uda.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0D3C0000-1EF7FFFF ERASE_REQUEST_BB5 : 5001120B0003000D3C00001EF7FFFF82 Successfully Erased... Total blocks to write : 228 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 05 Device Type : 0F Num Bad Blocks : 0000000A Additional Bad : 0000FFFF Correctable ECC : 0000FFFF FlashInfo.RestartMode : 1 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:05:20 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) SW: V ICPR72_11w16.3 05-12-11 RM-612 (c) Nokia IMEI: 356994044618332 CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Changing Phone Mode... (Wait for 10 seconds) Successfully set to : Normal |
09-11-2012, 13:38 | #3 (permalink) |
Member: 1507693 Status: Offline Thanks Meter: 131 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020416 Library Version : 00030118 Box Type : ATF Nitro Box Firmware : LogiCore 10.3.15 Software Version : v9.02 AdvanceBox SN : C311432CAB6C98938AEBED7E Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V ICPR72_11w16.3 05-12-11 RM-612 (c) Nokia IMEI Plain : 356994044618332 IMEI Spare : A356994044618330 IMEI SV : 33569940446183319F Phone Model: Nokia C6-00 Category : Classic Phone Phone Type : RM-612 ================================================ Extended Phone Information ================================================ Product Serial Number: MQN323204 Product Code : 0597688 Basic Production Code: 0588602 Long Production SN : 0 MCU SW Version : V ICPR72_11w16.3 05-12-11 RM-612 (c) Nokia HW Version : 1000 RFIC Version : |Vapaus_6.5 | Mikki_1.1 DSP Version : 11w13 AHNE Version : 11 APE SW Core Version : v 42.0.004 Variant Version : v 42.0.00442.0.004.08.0142.0.004.C01.01 APE Test Version : 0.020 RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : A8:E0:18:B8:79:E1 Bluetooth ID : A8:E0:18:B8:04:B1 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED CMLA_KEY : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... PHONE_MODE : TEST |
09-11-2012, 14:36 | #4 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Heart of Asia
Member: 1706168 Status: Offline Sonork: 100.1619095 Thanks Meter: 66 | First format file system then flash with same product code Flash completely select 5 files like this: 1-MCU 2-ROFS2 3-ROFS3 4-ENO 5-UDA post the result |
09-12-2012, 05:09 | #7 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
& post result Br - srinibas | |
09-12-2012, 10:24 | #8 (permalink) | |
Member: 1507693 Status: Offline Thanks Meter: 131 | Quote: I THINK I NEVER THOUGHT BEFORE DOING THIS, I HAVE DOWNGRADED THIS PHONE BUT NOW IT CANT GET INTO LOCAL MODE OR TEST MODE OR NORMAL MODE ,I HAVE DONE ALL THE STEPS: BACK UP RPL,FULL PM, ERASE PHONE ,WROTE ENO FILE, FULL FLASH THE PHONE BUT PHONE DIDNT BOOT INTO LOCAL MODE, WROTE RPL, AUTHORISE PHONE VIA ATF NETWORK ,BUT PHONE IS NO LONGER GETTING INTO LOCAL OR TEST MODE TO REPAIR SD, IF I PRESS POWER IT ONLY VIBRATES ARE YOU SURE THIS SOFTWARE CAN REALLY DOWNGRADE RAPIDOV11? I tried flashing again with latest version but still phone dead,is there any other ways to get this phone working or its dead until next update | |
09-12-2012, 10:52 | #9 (permalink) |
Member: 1507693 Status: Offline Thanks Meter: 131 | here is the flshing log Number of Image Files: 5 Processing Image File : RM-612_40.0.021_prd.core.C00 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 489 Entry Point: 0x2AC269 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-612_40.0.021.236.01_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 5 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00007000 Processing Image File : RM-612_40.0.021_prd.rofs2.V21 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 133 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM612_40.0.021_001_U236.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 251 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM612_APE_ONLY_ENO_10w49_v0.018.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 15 Entry Point: 0x0138 Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 07D00004 ID DWORD 1 : 62980252 ID DWORD 2 : B01CE127 ID DWORD 3 : A3FA702F ID DWORD 4 : 85D9549E 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0050 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 20000000 (512 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_XSR15_a lg.fg SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) SendCodeStart_NewProtocol SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 54 04 01 00 00 00 A5 VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 505A5C85580A6322C103BFE4E67B73EF478E791C START READING RPL DATA IMEI: 356994044618332 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... EMPTY NPC CERTIFICATE INFORMATION (CMT): IMEI : 365990444163823 PRODUCT CODE : 0597688 WLAN ID : A8:E0:18:B8:79:E1 BLUETOOTH ID : A8:E0:18:B8:04:B1 PUBLIC_ID : 07D0000462980252B01CE127A3FA702F85D9549E PAPUB_KEYS_HASH: 505A5C85580A6322C103BFE4E67B73EF478E791C CCC CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 0597688 HWC CERTIFICATE INFORMATION (CMT): PUBLIC_ID : 07D0000462980252B01CE127A3FA702F85D9549E PRODUCT CODE : 0597688 RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356994044618332\3569940446183 32_113003.rpl ImagePath: D:\Products\RM-612\ ImageFilename: RM-612_40.0.021_prd.core.C00 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00080000 Size : 019A0000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 01A20000 Size : 0B980000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0D3C0000 Size : 11BC0000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 1F140000 Size : 003C0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200080000019A0000000000040000000201A200000B9800 0000000008000000010D3C000011BC00000000000A00000001 1F140000003C0000EF PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x57 (87) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-00082FFF 1 : 00083400-003FFFFF 2 : 00800000-00D5FFFF 3 : 00D60000-0D39FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5004120B0003000004000000082FFF120B0003000008340000 3FFFFF120B0003000080000000D5FFFF120B00030000D60000 0D39FFFF5B FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000000000 0002000000640000000B000000020000000100000000000000 0033 Successfully Erased... Total blocks to write : 489 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [505A5C85580A6322C103BFE4E67B73EF478E791C] >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ImagePath: D:\Products\RM-612\ ImageFilename: RM-612_40.0.021.236.01_prd.rofs3.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0C4A0000-0D39FFFF ERASE_REQUEST_BB5 : 5001120B0003000C4A00000D39FFFF44 Successfully Erased... Total blocks to write : 5 >> CMT Rootkey Hash CERT : SOS+ROFS3 ImagePath: D:\Products\RM-612\ ImageFilename: RM-612_40.0.021_prd.rofs2.V21 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 094A0000-0C49FFFF ERASE_REQUEST_BB5 : 5001120B000300094A00000C49FFFF38 Successfully Erased... Total blocks to write : 133 >> CMT Rootkey Hash CERT : SOS+ROFS2 ImagePath: D:\Products\RM-612\ ImageFilename: RM612_40.0.021_001_U236.uda.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0D3C0000-1EF7FFFF ERASE_REQUEST_BB5 : 5001120B0003000D3C00001EF7FFFF82 Successfully Erased... Total blocks to write : 251 ImagePath: D:\Products\RM-612\ ImageFilename: RM612_APE_ONLY_ENO_10w49_v0.018.fpsx StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT ERASE_REQUEST_BB5 : 5001130D00534F532A454E4F0000000000DD Successfully Erased... Total blocks to write : 15 >> CMT Rootkey Hash CERT : SOS*ENO ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 05 Device Type : 0F Num Bad Blocks : 0000000A Additional Bad : 0000FFFF Correctable ECC : 0000FFFF FlashInfo.RestartMode : 1 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:05:12 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) WARNING: Phone is not in the Required Mode... Disconnect the Phone and Power it Up Manually. phone now vibrates only when i press power,its not starting up anymore,, |
09-12-2012, 13:48 | #10 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @Fragga I just look your logs carefully now, and it seems you didn't flash ROFS3 in the first post.... This is the reason for why phone is dead. On other post of you in this thread, you used ROFS3 also, but old version 40.xx = downgrade.. So now just download complete files of ANY latest available version and flash, same product code would be nice... BR |
09-13-2012, 14:54 | #11 (permalink) | |
Number of Image Files: 5 Processing Image File : RM-612_42.0.004_prd.core.C00 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 489 Entry Point: 0x2AD269 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-612_42.0.004_prd.rofs2.V08 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 130 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-612_42.0.004_C01_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 5 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00000E00 Processing Image File : RM-612_42.0.004_uda_2_001.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 228 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM612_APE_ONLY_ENO_11w42_v0.020.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 15 Entry Point: 0x0136 Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 07D00004 ID DWORD 1 : 62980252 ID DWORD 2 : B01CE127 ID DWORD 3 : A3FA702F ID DWORD 4 : 85D9549E 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0050 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 20000000 (512 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_XSR15_a lg.fg SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) SendCodeStart_NewProtocol SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 54 04 01 00 00 00 A5 VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 505A5C85580A6322C103BFE4E67B73EF478E791C START READING RPL DATA WARNING: Invalid NPC Block Detected... ERROR: NPC is Corrupted..., 3 RPL Backup is Skipped ImagePath: D:\Products\RM-612\42.0.4\ ImageFilename: RM-612_42.0.004_prd.core.C00 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00080000 Size : 019A0000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 01A20000 Size : 0B980000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0D3C0000 Size : 11BC0000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 1F140000 Size : 003C0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200080000019A0000000000040000000201A200000B9800 0000000008000000010D3C000011BC00000000000A00000001 1F140000003C0000EF PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x57 (87) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-00082FFF 1 : 00083400-003FFFFF 2 : 00800000-00D5FFFF 3 : 00D60000-0D39FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5004120B0003000004000000082FFF120B0003000008340000 3FFFFF120B0003000080000000D5FFFF120B00030000D60000 0D39FFFF5B FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000000000 0002000000640000000B000000020000000100000000000000 0033 Successfully Erased... Total blocks to write : 489 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [505A5C85580A6322C103BFE4E67B73EF478E791C] >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ImagePath: D:\Products\RM-612\42.0.4\ ImageFilename: RM-612_42.0.004_prd.rofs2.V08 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 094A0000-0C49FFFF ERASE_REQUEST_BB5 : 5001120B000300094A00000C49FFFF38 Successfully Erased... Total blocks to write : 130 >> CMT Rootkey Hash CERT : SOS+ROFS2 ImagePath: D:\Products\RM-612\42.0.4\ ImageFilename: RM-612_42.0.004_C01_prd.rofs3.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0C4A0000-0D39FFFF ERASE_REQUEST_BB5 : 5001120B0003000C4A00000D39FFFF44 Successfully Erased... Total blocks to write : 5 >> CMT Rootkey Hash CERT : SOS+ROFS3 ImagePath: D:\Products\RM-612\42.0.4\ ImageFilename: RM-612_42.0.004_uda_2_001.uda.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0D3C0000-1EF7FFFF ERASE_REQUEST_BB5 : 5001120B0003000D3C00001EF7FFFF82 Successfully Erased... Total blocks to write : 228 ImagePath: D:\Products\RM-612\42.0.4\ ImageFilename: RM612_APE_ONLY_ENO_11w42_v0.020.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00400000-007FFFFF ERASE_REQUEST_BB5 : 5001120B00030000400000007FFFFF21 Successfully Erased... Total blocks to write : 15 >> CMT Rootkey Hash CERT : SOS*ENO ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 05 Device Type : 0F Num Bad Blocks : 0000000A Additional Bad : 0000FFFF Correctable ECC : 0000FFFF FlashInfo.RestartMode : 1 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:05:13 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) WARNING: Phone is not in the Required Mode... Disconnect the Phone and Power it Up Manually. | |
09-13-2012, 15:07 | #12 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @Fragga Download complete flash package of the same Product code of your phone... It should also have VPL files etc,, from your logs, looks like you selected files manually... And if flash still doesn't resolve the problem, then you probably need to downgrade your phone. I hope you have all Backups already since you could get local mode before, if not have backups, still no problem - level 2 will help for sure... For instrcutions on How to downgrade and use level 2 - look at stuck threads... BR Last edited by ..::Angel::..; 09-13-2012 at 15:48. |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
09-13-2012, 16:17 | #13 (permalink) | |
I HAVE DOWNGRADED THIS PHONE,AND FULLY FLASHED IT WITH 5 FILES AUTO SELECTED BY ATF,FIRST I FULLY ERRASED THE CHIP,THEN FULL FLASHED PHONE , Number of Image Files: 5 Processing Image File : RM-612_20.0.043_prd.core.C00 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 479 Entry Point: 0x2AA869 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-612_20.0.043_C01_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 5 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00000E00 Processing Image File : RM-612_20.0.043_prd.rofs2.V04 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 131 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-612_20.0.043_uda_1_001.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 73 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM612_APE_ONLY_ENO_10w20_v0.014.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 15 Entry Point: 0x0136 Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ERROR: BOOTROM NOT DETECTED AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeded After 2 Tries SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 07D00004 ID DWORD 1 : 62980252 ID DWORD 2 : B01CE127 ID DWORD 3 : A3FA702F ID DWORD 4 : 85D9549E 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0050 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 20000000 (512 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_XSR15_a lg.fg SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) SendCodeStart_NewProtocol SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 54 04 01 00 00 00 A5 VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 FF BB Asic Index : 02 CMT PAPUBKEYS HASH: NO PAPUB KEYS RETURNED START READING RPL DATA WARNING: Invalid NPC Block Detected... ERROR: NPC is Corrupted..., 3 RPL Backup is Skipped ImagePath: D:\Products\RM-612\ ImageFilename: RM-612_20.0.043_prd.core.C00 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00080000 Size : 019A0000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 01A20000 Size : 0B980000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0D3C0000 Size : 11BC0000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 1F140000 Size : 003C0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200080000019A0000000000040000000201A200000B9800 0000000008000000010D3C000011BC00000000000A00000001 1F140000003C0000EF PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x57 (87) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-00082FFF 1 : 00083400-003FFFFF 2 : 00800000-00D5FFFF 3 : 00D60000-0D39FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5004120B0003000004000000082FFF120B0003000008340000 3FFFFF120B0003000080000000D5FFFF120B00030000D60000 0D39FFFF5B FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000000000 0002000000640000000B000000020000000100000000000000 0033 Successfully Erased... Total blocks to write : 479 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [505A5C85580A6322C103BFE4E67B73EF478E791C] >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ImagePath: D:\Products\RM-612\ ImageFilename: RM-612_20.0.043_C01_prd.rofs3.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0C4A0000-0D39FFFF ERASE_REQUEST_BB5 : 5001120B0003000C4A00000D39FFFF44 Successfully Erased... Total blocks to write : 5 >> CMT Rootkey Hash CERT : SOS+ROFS3 ImagePath: D:\Products\RM-612\ ImageFilename: RM-612_20.0.043_prd.rofs2.V04 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 094A0000-0C49FFFF ERASE_REQUEST_BB5 : 5001120B000300094A00000C49FFFF38 Successfully Erased... Total blocks to write : 131 >> CMT Rootkey Hash CERT : SOS+ROFS2 ImagePath: D:\Products\RM-612\ ImageFilename: RM-612_20.0.043_uda_1_001.uda.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0D3C0000-1EF7FFFF ERASE_REQUEST_BB5 : 5001120B0003000D3C00001EF7FFFF82 Successfully Erased... Total blocks to write : 73 ImagePath: D:\Products\RM-612\ ImageFilename: RM612_APE_ONLY_ENO_10w20_v0.014.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00400000-007FFFFF ERASE_REQUEST_BB5 : 5001120B00030000400000007FFFFF21 Successfully Erased... Total blocks to write : 15 >> CMT Rootkey Hash CERT : SOS*ENO ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 05 Device Type : 0F Num Bad Blocks : 0000000A Additional Bad : 0000FFFF Correctable ECC : 0000FFFF FlashInfo.RestartMode : 1 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:04:03 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Operation Cancelled... Phone is not Connected OR it is not in the Required Mode... Reboot the Phone and Enable "PC Suite" Mode Operation Cancelled... | |
09-14-2012, 09:37 | #14 (permalink) |
Member: 1507693 Status: Offline Thanks Meter: 131 | Support where are you now? you only do one reply per day and yet its not working,why would you do that Atf team???its now 3days while im with this phone,if there is no solution then you have to say that dont be that silent,,im not happy regards br fragga |
09-14-2012, 10:53 | #15 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @Fragga Solution is already in my previous post... I told you to do Full Erase Flash... Make sure you have all Backups, about Full Erase Flash - all written in stuck threads.. BR |
