07-13-2015, 12:39 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | Help repair boot lumia 520 via usb Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Recovery Handle Found! - (WinUSB) Sending Factory Loader... Loader Upload Done! Executing Loader... |
07-13-2015, 15:58 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Fragga The main problem is that there are many many many many many versions of Qualcomm Drivers... and some version act different to newer versions... A better solution is to always use "Nokia Emergency Drivers" You can download the latest version here: http://174.120.45.27/tmp/EmergencyDo...Driver_new.rar Once you "force" windows to use those Nokia Emergency Drivers instead of the currently installed Qualcomm Drivers... most of your problems will disappear. And you will be able to fix the phone... assuming that the eMMC is not broken. B.R. |
07-13-2015, 19:54 | #3 (permalink) |
Member: 1507693 Status: Offline Thanks Meter: 131 | but on device manager shows Nokia Emergency Connectivity Im using a clean pc, no other driers installed except for nokia drivers only, please help me anyway you can |
07-13-2015, 21:31 | #4 (permalink) |
Member: 1507693 Status: Offline Thanks Meter: 131 | Problem solved, the phone was rm-915and i was trying to recover using rm-914, the was changed the body, and outside written rm-914 yet phone inside was rm-915, found out when i wanted to do jtag, so i opened and saw the motherboard is rm-915, hapy now |
