05-02-2014, 06:34 | #1 (permalink) |
No Life Poster Join Date: Oct 2005
Member: 190377 Status: Offline Thanks Meter: 61 | [Help] SM-C101 hard bricked for imxx patch firmware Enviado desde mi iPhone con Tapatalk |
The Following User Says Thank You to littmanr For This Useful Post: |
05-02-2014, 06:38 | #2 (permalink) |
Member: 190377 Status: Offline Thanks Meter: 61 | I tried with i9300 and n7100 so no success, these devices using same eMMC controller. I think i9500 have same eMMC controller with SM-C101 but different CPU. Really I need your help. Enviado desde mi iPhone con Tapatalk |
05-02-2014, 06:51 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Hi, Have you tried making SDC file using Original Samsung 4 Files + PIT? You need to find CMD connection of eMMC as well, and short the pull-up resistor of the CMD line. Take a better picture of the eMMC area, so we can suggest to you where to TP the phone. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
05-02-2014, 06:57 | #4 (permalink) |
Member: 190377 Status: Offline Thanks Meter: 61 | Its necessary 4 files, I found only one file packaged. Any tool for open this and dump all files? Enviado desde mi iPhone con Tapatalk |
05-03-2014, 05:16 | #6 (permalink) |
Member: 190377 Status: Offline Thanks Meter: 61 | Sorry for delay, My high quality camera was damaged, so I upload picture with my mobile, I found 1 resistor with 1.8V, check picture, if u need more picture please notify me. However for build sdc file with 4 files I cant make because dont found any tool for unpackage all files. If u have full fw please build for to test here. King Regards. |
05-03-2014, 05:37 | #7 (permalink) |
Member: 190377 Status: Offline Thanks Meter: 61 | Brother I downloaded this FW C101UBUAMJ1_C101UUBAMJ2_C101UBUAMJ1_HOME.tar.md5 its containing: boot.img cache.img camera.bin hidden.img modem.bin recovery.img system.img |
05-04-2014, 00:12 | #10 (permalink) |
Member: 190377 Status: Offline Thanks Meter: 61 | Hi support I wrote sdc file in 32Gb sd card, I wait dont have any problem for to use that capacity. Please help with Pull-Up Resistor for short TO gnd. ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x28 Application ID : BE Product Name : Product Revision : 1.0 Serial Number : BA52B026 Manufacture Date: July 2012 Card CID: 284245202020202010BA52B02600C743 Card CSD: 400E00325B590000EE8D7F800A40002D Card SCR: 0235800000000000 Card OCR: 00C0FF8000 SD Card Size : 32018268160 Bytes SD Block Size: 512 Bytes Maximum Speed: 25000000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is NOT Password Protected!!! Erasing SDC... Samsung SM-C101 UNBRICK 4.2.2 Start Writing to SDC at 0x00000000... Number of Blocks: 0x00001000 Process Done... ================================================== ==== 1. Solder THIN WIRE to Test Point Location A and B 2. Connect Test Point A and B Together 3. Assemble Phone with LCD 4. Make Sure Battery is Fully Charged 5. Press Power Button and Wait for SDCARD MODE Menu 6. Press Volume DOWN KEY to Enter DOWNLOAD MODE 7. DISCONNECT Test Point A and B Connection 8. Flash the Phone with ODIN ================================================== ==== Total Elapsed Time 00:00:06 Write Success! |
05-05-2014, 07:01 | #11 (permalink) |
Member: 190377 Status: Offline Thanks Meter: 61 | Hello advance team I purchased service manual but level 3 apartment not delivered. Please, if you have schematic please send me for try to locate Cmd pull-up resistor. Thank you Enviado desde mi iPhone con Tapatalk |
10-01-2014, 14:50 | #12 (permalink) |
Member: 190377 Status: Offline Thanks Meter: 61 | Hi support Could you to build .sdc file from this fw C101XWUAMG1_OJVAMG2_TUR_Turkey_Android_4.2.2". That version was used for octopus patch, and kill my device. Thank so much |
10-02-2014, 13:46 | #15 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @littmanr But I think IMEI patch is not damage BOOT1 which this Camera uses. Anyway, check your service manual. CMD Resistor I think is R312 Use Multitester to confirm that it is a 10K Ohms Resistor. You can find it on the side of UME300. You already have SDC file right? |
