03-18-2011, 10:24 | #1 (permalink) |
Freak Poster Join Date: Apr 2007
Member: 488365 Status: Offline Thanks Meter: 12 | help unlock 6120c new hasg 47xxx |
03-18-2011, 10:33 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Your box must be activated for ATF Network account and you must have least 5 credits in your box. How to unlock: 1. Authorize phone from ATF Network tab 2. Go to IMEI and Locks 3. Click SL1/SL2 simlock repair BR | |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
03-18-2011, 10:33 | #3 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: India\China
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks Meter: 948 | Quote:
dear, first u need atf network activation+atf credits. 5 credit only need for bb5 authrization then go to imei & lock tab & tick (repair simlock sl1 & sl2). execute the task. http://forum.gsmhosting.com/vbb/f609...25/index4.html & you dont need any sl3 brute force, it will unlock directly. Wbr s n hasan | |
04-05-2011, 13:47 | #4 (permalink) |
No Life Poster Join Date: May 2009 Age: 49
Member: 1027729 Status: Offline Thanks Meter: 97 | MCU: V 07.20 05-10-09 RM-243 (c) Nokia IMEI: 359342039104115 Model : Nokia 6120 Product Serial Number: MJI637045 Product Code : 0548276 Basic Production Code: 0539292 Default SN Type : 0 PPM Version : V 07.20 05-10-09 RM-243 (c) Nokia HW Version : 0602 RFIC Version : 17141716 DSP Version : 06w41pb_08w28.0.3_rm243 AHNE Version : 11 APE SW Core Version : 07.20 APE Variant Version : rofs_version_inforofx_version_info APE Test Version : rm243_ENO_A_2009wk15v0.100 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL1/PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : LOCAL MODE ================================================== = SL1/SL2 Simlock RPL Stand Alone Edition ================================================== = Generating Simlock Dongle RPL... (This may take upto 30 Seconds on New RAPIDO HASH) -> OK: Simlock RPL accepted VBATT OFF... VBATT ON Setting VBATT Done!... Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s MCU: V 07.20 05-10-09 RM-243 (c) Nokia IMEI: 359342039104115 Model : Nokia 6120 Product Serial Number: MJI637045 Product Code : 0548276 Basic Production Code: 0539292 Default SN Type : 0 PPM Version : V 07.20 05-10-09 RM-243 (c) Nokia HW Version : 0602 RFIC Version : 17141716 DSP Version : 06w41pb_08w28.0.3_rm243 AHNE Version : 11 APE SW Core Version : 07.20 APE Variant Version : rofs_version_inforofx_version_info APE Test Version : rm243_ENO_A_2009wk15v0.100 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL1/PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 SUPER_DONGLE_TEST : PASSED ================================================ SL1/SL2 Phone detected ================================================ PHONE_MODE : TEST MODE ???????????????????? SECURITY AREA FAILD AFTER UNLOCK NOW PHONE IN CONTECT RETAILER WRITE PM ABD SD REPAIR NOTHING HAPPED HELP ME |
04-05-2011, 13:51 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @lasertec_06 Go to PM Tab and select Customized SX4 and write PM 1 and 309 RM-243.pm SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 |
04-05-2011, 19:09 | #12 (permalink) |
Freak Poster Join Date: Jan 2004 Location: hong kong Age: 56
Member: 51463 Status: Offline Sonork: 100.1596671 Thanks Meter: 29 | 6120C new hash 479C hello Advance-Box team master is it after active ATF Box 99 credit . and only use 5 credit unlock this phone ?? ,,,is direct unlock or need something brust-forse calculatione code , please tell here clear ,, thank you very much ,,,,,, |
04-05-2011, 19:12 | #13 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @kin88 For 6120c with NEW HASH,, you do not need Brute Force. Just 5 credits for authorize phone and then select "Direct Unlock (SL1 and SL2)" It will be unlocked. B.R. |
04-06-2011, 08:37 | #14 (permalink) |
Member: 1027729 Status: Offline Thanks Meter: 97 | thanks for support atf team problem solved atf best MCU: V 07.20 05-10-09 RM-243 (c) Nokia IMEI: 359342039104115 Model : Nokia 6120 Product Serial Number: MGF332688 Product Code : 0567116 Basic Production Code: 0539292 Default SN Type : 0 PPM Version : V 07.20 05-10-09 RM-243 (c) Nokia HW Version : 1102 RFIC Version : 17141716 DSP Version : 06w41pb_08w28.0.3_rm243 AHNE Version : 11 APE SW Core Version : 07.20 APE Variant Version : rofs_version_inforofx_version_info APE Test Version : rm243_ENO_A_2009wk15v0.100 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL1/PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
