02-16-2013, 22:56 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 457589 Status: Offline Thanks Meter: 23 | Help us please - [SOLVED, CHECKED HIS BOX IS OK ALREADY] I bought a big turbo Box AND Last Update And worked All fully 1 - 6600 (CONTACT) Box originally did not feel the device solved on BEST-MX BOX-HWK 2 - 7610 (symbol) Box originally did not feel the device solved on BEST-MX BOX-HWK 3 - Nokia 5130 (Nokia then white screen) NO USB F BUS fully taking the MCU 50% AND THEN DED solved on BEST-MX BOX-HWK 4 - Nokia e63 (UPDATE) solved on BEST-MX BOX-HWK 5 - Nokia E66 (UPDATE) solved on BEST-MX BOX-HWK The only interest has done with me he decoder Memory Card Where the error in the Box or update? I've noticed in other forums Some users find some mistakes in the Box Please attention of supported |
02-17-2013, 10:19 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | It is a strange mater , not for me for our rivals , World know our credibility , May be little bug there , it is a continuous process to rectify the bug as reported . Either you don't know how to use ATF or not install properly . Can you please post the error log here Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
02-17-2013, 13:39 | #3 (permalink) |
Member: 457589 Status: Offline Thanks Meter: 23 | I know sir you stronger support team in the world I know and others know the credibility of the process I hope the support team handling errors in the next release We are users here in the Middle East go and all strength to buy this great Box So we call it (Box future) I noticed that Box does not feel some mobile devices ordinary cable or USB Greetings to you |
02-17-2013, 14:25 | #4 (permalink) |
Member: 457589 Status: Offline Thanks Meter: 23 | See, sir, 5130 did not respond plug USB And then asked Box F-Bus cable ATF Software Version v9.51 ATF Box FBUS Flash Started... Number of Image Files: 3 Forcing Test Mode via BUSCHECK... Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 17E00009 ID DWORD 1 : 121C0256 ID DWORD 2 : A8C38280 ID DWORD 3 : 4BF6154A ID DWORD 4 : 8A32B53B 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 66 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Scanning Simlock Applet Type... OK ================================================= PA_SL3 Applet detected ================================================= * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ MCU Version: V 07.91 29-10-09 RM-495 (c) Nokia IMEI Plain : 354344043919244 IMEI Spare : A354344043919240 IMEI SV : 33543440439192447F Phone Model: Nokia 5130c-2 Category : Classic Phone Phone Type : RM-495 PM 120 Found... PM 308 Found... Simlock Data Saved to : C:\AdvanceBox Turbo Flasher\Nokia\Backup\354344043919244\SL3_certifica te_V 07.91 29-10-09 RM-495 (c) Nokia_354344043919244__031709.pm Changing MODE : FLASH Booting Phone via FBUS... BootFlashModeDCT5Ex Failed Failed to complete RPL backup.. Processing Image File : D:\Products\RM-495\rm495__07.97.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 1178 Entry Point : 0x5057 Page Format : 128K Maximum Page Size : 0x00004000 Changing MODE : FLASH Booting Phone via FBUS... BootFlashModeDCT5Ex Failed Operations Failed.... |
