09-19-2012, 09:28 | #1 (permalink) | |
No Life Poster Join Date: May 2008 Location: Dubai(U.A.E) Age: 37
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | hi team lumina unlock problem Quote:
I press and hold Volume Up as software says, but every 30seconds phone vibrate short and not flash. help me plz its urgent thanks | |
09-19-2012, 14:40 | #3 (permalink) |
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== Switching to NOKIA MODE Polling Ports... (Please Wait) ================================================ Basic Phone Information ================================================ SW Version : 1750.0805.8779.12221 IMEI Plain : 351682052340072 HW Version : 112.1402.2.4 Product Code : 059N3C5 Basic Product Code: 059J2N6 Module Code : 0205051 PSN Number : 0156248AB NCSD Version : 1.9 ================================================ Extended Phone Information ================================================ Public ID : 817353B614692DE8141EDF2B76126FAC Wireless Lan ID: 04:5A:95:63:62:1B:00:00 Bluetooth ID : 04:5A:95:65:17:76:00:00:00:00:00:00 Rebooting to OSBL MODE pls help me flashing not done |
09-19-2012, 19:31 | #6 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @delux_gsm Full Flash phone with this: 1750.0805.8773.12220_017 Your firmware is too high and is not compatible with the AMSS file that you flashed to your phone. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
09-20-2012, 10:28 | #8 (permalink) |
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 001A5C07 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:20 done thanks atf team |
09-20-2012, 10:56 | #9 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, good, its done... Please consider posting success logs only in this thread: http://forum.gsmhosting.com/vbb/f609...-logs-1536337/ BR |
09-29-2012, 19:27 | #12 (permalink) | |
No Life Poster Join Date: Mar 2010 Location: unlockprice.com
Member: 1263622 Status: Offline Thanks Meter: 149 | Quote:
download....ok....but flash failed.... download file size 390Mb.other tested file download link give me plz??????? | |
