Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 10-25-2012, 10:32   #1 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
How can i unlock Nokia 710 Rm-809?
How can i unlock Nokia 710 Rm-809 with atf?
what cable for use test point and where for testpoint?
pls help me all user
thanks
Old 10-25-2012, 11:10   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Hi,
You can use simple RJ45 cable. Pinouts are available here:
C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX
Unlocking procedure can be found here:
http://forum.gsmhosting.com/vbb/8866443-post19.html
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 10-25-2012, 11:22   #3 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Originally Posted by ..::Angel::.. View Post
Hi,
oh in my pc "
C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX"it not have the pichure
my ATF v9.15
how can i get it?
thanks
Old 10-25-2012, 11:24   #4 (permalink)
Member: 643472
Sonork: 100.96901
Originally Posted by 089999945 View Post
oh in my pc "
my ATF v9.15
how can i get it?
thanks
Update Important files from Product Support tab
Old 10-25-2012, 11:59   #5 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Now i got it
thank so much
Old 10-26-2012, 04:12   #6 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
when i click button Test connection it work well
Lumia Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
Reading Platform Information...
Selecting Active Handle...
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 710 Detected
Storage Device Information
Manufacturer ID: 90
Application ID : 014A
Product Name : HYNIX
Product Rev : 5D
Product SN : 0110E712
Protection Information
Write Protect A: OFF
Write Protect B: OFF
when i click sp unlock it show like this
ERROR: Select Correct Phone Type!
Total Elapsed Time 10:06:02
i choose correct phone type ready "710 rm-809"
pls help me all user and team
thanks
Old 10-26-2012, 06:01   #7 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Attach the photo copy of your TP solder
Dont use long jumper wire
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Old 10-26-2012, 07:56   #8 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Br - srinibas
sorry i can't upload pic "my internet have problem"
yes i use shortly
pls help me
thanks
Old 10-26-2012, 09:38   #9 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
i'm waitting solution
thanks
Old 10-26-2012, 10:26   #10 (permalink)
Member: 643472
Sonork: 100.96901
@089999945
You didn't select Product Type.
Check what's written in the procedure:
How to unlock Lumia phones:
1. Make sure appropriate model is selected from Windows Phone tab;
2. Solder TP wires on phone's board;
3. Select Correct Phone Type from TP Services tab;
4. Click on "Test Connection" button;
5. Connect USB cable to phone;
6. Once phone is detected by software, click on SP Unlock button;
7. Wait 2-4 Minuets and phone will be unlocked;
8. Disconnect phone from USB cable, de-solder TP wires;
9. Power on phone with Non-accepted SIM card;
X. Type 8 times zero "0" on PIN code and 10 times zero "0" on PUK code.
Page generated in 0.20481 seconds with 8 queries
