08-24-2013, 20:44 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: bangladesh
Member: 1022144 Status: Offline Sonork: Love in Bangladesh Thanks Meter: 139 | strange problem Nokia 200 !!! when i select English or other language without bangla , this time camera not open hang & restart but when i select bangla language this time camera open & capture photo . why this problem & how to solved ? already flash with ATF box 100% done & all pass |
08-25-2013, 08:23 | #2 (permalink) |
Member: 1022144 Status: Offline Sonork: Love in Bangladesh Thanks Meter: 139 | ================================================== ==== ================================================== ==== USB Phone BUSCheck Boot ================================================== ==== ================================================== ==== Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 1200100F991A2823 Original Product Code: 059K7X1 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355482057139306\3554820571393 06_125818.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355482057139306\3554820571393 06_CERTIFICATE_6C23510A.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355482057139306\3554820571393 06_PMM_PROT_22FA1FB6.bin Security Code: 12345 Infineon USB Buscheck Done Phone Restart Mode: TEST MODE Process Done... Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 11.95 19-12-12 RM-761 (c) Nokia IMEI Plain : 355482057139306 IMEI Spare : A355482057139300 IMEI SV : 33554820571393012F IMEI (2nd) : 355482057139314 IMEI Spare : A355482057139310 IMEI SV : 33554820571393112F Phone Model: Nokia 200 Category : Entry Phone Phone Type : RM-761 ================================================ Extended Phone Information ================================================ Product Serial Number: DF2A89AAH Product Code : 059J4P7 Module Code : 0205216 Basic Production Code: 059K7W6 Long Production SN : 0 PPM SW Version : V 11.95 19-12-12 RM-761 (c) Nokia BG BT MCM Version : 19e2-47026 MCU SW Version : V 11.95 19-12-12 RM-761 (c) Nokia HW Version : 1002 RFIC Version : Dummy RFIC version LCD Version : AUO Content Pack Version : Content: bg_059N5N9 V 11.95 19-12-12 RM-761 (c) Nokia Bluetooth ID : 54:79:75:7E:F7:F3 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000003000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 06150123 DCC Ver: 008027 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
09-13-2013, 06:15 | #6 (permalink) | |
No Life Poster Join Date: Aug 2009 Location: India, W.B, Kolkata
Member: 1093574 Status: Offline Sonork: 100.1646163 Thanks Meter: 474 | Quote:
TRy to flash with Other Flash File. Yr "cabinet file" can be damage of this flash file. | |
The Following 2 Users Say Thank You to binaybiswas For This Useful Post: |
