11-30-2013, 14:06 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Germany
Member: 396421 Status: Offline Thanks Meter: 87 | How to connect Lumia 820 under WinXp As far as i know for Zune for WP8 phones is minimum win7 required. Is there anyway a chance to install proper drivers to work with ATF under winXp and WP8 phones? i have here a Lumia 820 and problems to read phones info. hope somebody can help me. br |
11-30-2013, 14:26 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Connect Lumia in Normal Mode Window will load drivers, click on Cancel on first driver that windows will load. On second, install driver from this dir: C:\AdvanceBox Turbo Flasher\Driver\Lumia and Asha Phone Drivers The second driver will be for Nokia Connectivity USB Device. If its installed, then you can Scan Phone and can also flash it without other uninstalled drivers. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
11-30-2013, 14:36 | #3 (permalink) |
Member: 396421 Status: Offline Thanks Meter: 87 | i have in device manager Portable Devices: Lumia 820 Universal Serial Bus Devices: WinUsb Device (NULL) WinUsb Device (NULL) i think drivers are correct, yes? |
11-30-2013, 14:56 | #4 (permalink) | |
Member: 396421 Status: Offline Thanks Meter: 87 | i just now tried to flash the device and i have this log Quote:
This kind of phones cant be flashed? | |
11-30-2013, 15:14 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @huzein This is DEVELOPEMENT PHONE. You cannot flash this with regular non development firmware. You will notice you will see many "Z" apps inside... Another hint is Debug Status: Not Active Again, you cannot flash this phone... And as I know, it will not get any signal. Return to Customer. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
11-30-2013, 15:47 | #7 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Read Phone Info should be enabled if correct drivers are installed. Other than this, check other running programs such as Zune or Nokia Care suite or other Nokia 3rd party software running. They will prevent read info in ATF properly... Again, just return phone to customer because there is nothing you can to do this phone and customer might blame you why his phone does not have signal etc... | |
11-30-2013, 15:56 | #8 (permalink) |
Member: 396421 Status: Offline Thanks Meter: 87 | yes, already told to customer to come and take his phone. ok thanks, i will try next time when i get a Lumia 820. Other Lumia models reading phone's info worked so far. ok, thanks sir. BR |
