11-26-2014, 18:00 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | How to create own SDC - Samsung Debrick files with only BOOTLOADER Go to ATF Plus->Image Tool-> and Select BL - Bootloader File Check PIT option and select Generic PIT from drop-down list. From now on you can select Generic Samsung PIT file in order to create SDC files. If you DO NOT have proper PIT for you phone In my case model was SM-N910C - it is EXYNOS OCTA 5433 BL and Generic PIT selected, in Discription: write firmware version of your BL, my was 4.4.4 KitKat :-) Click Create SDC File button: SDC created successfully and saved to: \AdvanceBox Turbo Flasher\SD_Card\SDC_IMAGE |
The Following 20 Users Say Thank You to ..::Angel::.. For This Useful Post: |
12-04-2014, 13:18 | #9 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Can be this list can help many user for know wath's you Generic PIT for you phone: Quote:
BR allumts | |
12-10-2014, 08:47 | #14 (permalink) |
No Life Poster Join Date: May 2006 Age: 44
Member: 278546 Status: Offline Thanks Meter: 145 | please make sdc file by using below file . N900A_UCUCNC2_ATTCNC2 (1) - Download - 4shared - tredd yala it is 4.4.2 |
The Following User Says Thank You to yalamandareddy For This Useful Post: |
12-10-2014, 10:17 | #15 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Make yourself Sdc file, this thread is been created for this purpose, N900A is Qualcomm platform no need TP, only Sdc File, use Original Sd Card like San Disk, Samsung itc... NO fake CINA Sd Card and size must be how Atf Sw>Create Immage> requiere, have all write clear above, read and apply. BR | |
The Following 3 Users Say Thank You to allumts For This Useful Post: |
