12-10-2014, 11:46 | #17 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
This Kingston are sure not is Fake one?, Sd card is very important, if is NOT original phone not detect this, anyway post screenshoot BR allumts | |
12-12-2014, 15:02 | #18 (permalink) |
No Life Poster Join Date: Sep 2008 Location: in your hart Age: 40
Member: 864102 Status: Offline Sonork: 100.1617637 Thanks Meter: 146 | problem in creating sdc file when i creat samsung i9500 android 4.4.2 its show only 600kb here is i attached pic were i m wrong please chek. 1st image with genric it file and 2nd image with og pit file |
12-12-2014, 15:30 | #19 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Why you select PDA and no BL?, you cannot see alone where's the ERROR? BL +PIT for create Sdc file by yourself, NOT AP/PDA+PIT. (ONLY SINGLE FILE BL) Read good the procedure BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
12-13-2014, 08:51 | #22 (permalink) | |
please Post here File Used for create by yourself Sdc file: BL and PIT and remember that you are using only BL+PIT, size cannot be the same how if use 4 file fw+ PIT, but is working the same. BR allumts | |
12-14-2014, 11:08 | #23 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @moinuddin111 SDC is OK as long as you use BL + PIT. Also, this is Exynos CPU and file size for these CPU SDC is: 230+ Kbs to 600+ Kbs For Qualcomm CPUs: 3MB+ to 32+MB MAX BR |
12-18-2014, 02:29 | #25 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | |
12-26-2014, 12:36 | #29 (permalink) | |
http://forum.gsmhosting.com/vbb/10717329-post9.html Br allumts | |
12-30-2014, 12:52 | #30 (permalink) |
Insane Poster Join Date: Dec 2007
Member: 656769 Status: Offline Thanks Meter: 3 | sir i have a question can i make a sdc file from a sam i5800 bootloader file... it is deadboot... it has no recovery. it hangs on i5800 logo... if possible what are the settings to be used.? |
The Following User Says Thank You to jolly88888 For This Useful Post: |
