Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-11-2015, 21:44   #76 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Originally Posted by byteforce View Post
I am trying to make a SDC file from a file
G360FXXU1AOA1_OXA1AOA1
that has all the files inside, and when I try to revive the phone it doesn't give any sign of life at all.
I tried using the PIT file that I have
COREPRIMELTE_EUR_OPEN.pit
but also using the Generic PIT file method and selecting MSM8916 as chipset but again the same
Maybe I need to extract the only 5.0.2 flash file
G360FXXU1BOD9_OXA1BOD9_XEO_Poland_5.0.2
and then using those Bootloader files??
@byteforce and ALL
You must need of BL file from Stok Fw and PIT, no more.
So:
A) Unrar the Stock Fw that you want use, you'll have all Files in one Folder, (can be 9/10/12 sigle files), depend from the Stock Fw
B) Download and Install one of the more FREE program for create by yourself 4 part flash files from Stock FW: BL, AP/PDA, CP/MODEM, CSC
C) for only create by yourself Sdc File and Sd Card must need only BL file (.Tar.Md5), an PIT file for this model or Default PIT from Atf Folder
D) Insert one GOOD Sd Card in Card Reader slot, (for BIG ATF), in Adapter 4 in 1, (for Atf Nitro/Light), like San Disk, Samsung, itc... NO FAKE CHINA CARD, (not work Sd Card create later), of the size request, 2/8/16/32GB depend what sw requiere,
E) In Atf Sw select "Image Tool", Press CREATE Button and wait good result... if have done all right sw say you the steps must need for D.Mode phone
F) If is all ok and you phone enter in D.Mode, TAKE OUT SD CARD FROM PHONE, IT'S IMPORTANT, and Flash 4 part flash file of Same Above Fw that have created Sd Card from Sdc File...NO OTHER FW <<<< IMPORTANT
G) no step G
NOTE: NOT USE DIFFERENT FW of SDC CARD CREATE, NOT CREATE SDC file and SD CARD from ONE FW MORE LOW VERSION OF THE FW FIRST OF THE BRICK, if not are sure what fw had before, for to be sure USE MORE HIGH FW That Existe for this Phone.
Is very Easy, i've Explained one time for all for ALL USER that send request here. Lost of you time and no receive Help for Create New SDC file, so NOT TO BE LAZY and CREATE in 2 EASY STEPS you own Sd Card.
No more guide or explanaction i do, this is last time.
Please any Thanks Post, use only Thanks Button if this guide is been of help for you
allumts
The Following 2 Users Say Thank You to allumts For This Useful Post:
Old 07-12-2015, 20:12   #77 (permalink)
Member: 831885
Thanks Meter: 10
i have a dead sm e500f to repair boot
how to repaire dead boot sm e500f its dead after write qcn
Old 07-12-2015, 20:50   #78 (permalink)
Cheater -Don't Deal with him-
Member: 21296
Thanks Meter: 328
@allumts
Gave you a thanks for trying to help many ATF users in their efforts to repair Dead phones.
I have seen you are trying to help every user, but unfortunately your English is so poor.
Sorry to say this.
Now my specific problem is the phone I searched all over the forums G360F, and seems I am the first one to kill such a phone. Found nothing regarding this phone and no ready made SDC for this phone too. When it came to unlock to me it was version 5.0.2 of Android.
I was trying to dongrade it to v4.4.X of Android.
Now the only downloadable file v5.0.2 for this phone is this:
but it contains only one file inside and I extracted it with WinRAR to make the Bootloader needed for SDC creation but when extracted there is no sboot.bin and param.bin file required inside to create the bootloader file according to some tutorials here:
http://forum.gsmhosting.com/vbb/f777...100-a-1860706/
and here:
[GUIDE] Extract bootloader and Make flashabl&hellip; | Samsung Galaxy S III I9300, I9305 | XDA Forums
So my question is who can help me to create a SDC file for this phone, I would appreciate it very much as I am unable to proceed further.
I am going to buy a new phone to customer, but I need to repair the phone afterwards.
Is this phone revivable by ATF SDC file? Can somebody clarify it to me? This phone has: CPU: Qualcomm Snapdragon 410 MSM8916 according to Samsung SM-G360F Galaxy Core Prime LTE Specs | Technical Datasheet | PDAdb.net
And is the SD card size important when writing SDC file? or need to be exact size as specified by ATF SDC file? ( I understood that the SD card needs to be original and good)
Big thanks for anybody who help me to find Bootloader file, or ready made SDC file for my phone.
Old 07-12-2015, 21:19   #79 (permalink)
Member: 21296
Thanks Meter: 328
As you can see, I created bootloader file with just boot.img file that is found when extracted the whole flash, but ATF says:
SDC UNBRICK Image Creator Version 2.9
Analyzing PIT Structure...
Default SD Card Size: 7818182656 Bytes (8 GB)
Preparing RAW Values for MSM8916...
Analyzing Boot Structure...
PIT is OPEN + Signed...
Mounting Virtual Disk...
Checking Bootloader Files...
Start Writing Partitions...
ERROR: BOOTLOADER Files are NOT COMPLETE!
This Flash File cannot be used for SDC Creation
So happens because no sboot.bin and no param.bin inside that whole flashfile:
Old 07-12-2015, 22:22   #80 (permalink)
Member: 21296
Thanks Meter: 328
I also created now a Bootloader .tar.md5 file for 5.0.2 firmware using the files as Bootloader of the provided original 4.4.4 firmware
G360FXXU1AOA1_OXA1AOA1 contains
who includes many files apart from boot.img, sbl.mbn, hyp.mbn, sbl1.mbn etc, and wrote to the SDC file to SD card but no sign of life from the phone.
Whenever I go to create new SDC files by ATF , ATF displays Target size lower - first says 16 GB, then at another try of creation ATF says 8GB , then 4 GB etc.
Old 07-13-2015, 14:28   #81 (permalink)
allumts's Avatar
Member: 1564612
No need to make experiment....Read carefully my guide and not to do how you want... use this other program EASY if not are good with CIGWIN:
http://forum.gsmhosting.com/vbb/f777...bbasi-1943171/
Need All BOOT file for one Good Sdc File, not only one Boot.img file...
Anyway if not are good to create one easy Sdc File and Sd Card try with solder EMMC DIRECT wires and Write Stock Fw .tar.md5.
And NOT use Low version FW then had phone first of BRICK...have wrote above, FOR SURE use Last High Fw for you Phone.
Old 07-14-2015, 10:40   #82 (permalink)
Member: 21296
Thanks Meter: 328
This model seems to unrecoverable just by SDC file. I Have tried all possibilities, but no sign of life from this phone. And as I am not skilled, nor do I prefer to open phones, then I am going to buy a new phone for the customer (because JTAG or eMMC is not an option for me )
Old 07-14-2015, 11:03   #83 (permalink)
allumts's Avatar
Member: 1564612
FOR ALL
Who have need 4 part file Fw Ready for use, (ceck always if more high version you had first in Bricked phone), can Find HERE:
allumts
Old 07-14-2015, 11:19   #84 (permalink)
Member: 21296
Thanks Meter: 328
One other chance that I see is to find the CPU TP location to short for forcing phone to enter SDC mode, but no reply from any of official ATF supporters till now!!!
G360F CPU TP location for forcing phone to enter download mode via SDC needed badly.
Thanks for anybody who can help me.
Old 07-14-2015, 12:16   #85 (permalink)
Member: 355613
Sonork: 100.1674359
Thanks Meter: 170
Need sm-t325 sdc no donr by tar file
Old 07-14-2015, 14:46   #86 (permalink)
Member: 52905
Thanks Meter: 2
On A500FU must open phone or only debrick SD card is enough? Phone is dead after downgrade from 5.0.2 to 4.4.4.
For debrick SD card is enough a sdc file ?
The Following User Says Thank You to bubu782001 For This Useful Post:
Old 09-02-2015, 08:54   #87 (permalink)
Rex
Member: 3468
Thanks Meter: 308
Hi,
what is compatible pit for Exynos 5260? i don't see in the list of image tool.
Old 09-02-2015, 09:32   #88 (permalink)
allumts's Avatar
Member: 1564612
Yupppppppp..ATF SECTION now is SAMSUNG BOX SECTION.
Loock that for repair any New Samsung Downgrated from 5.0.2 to 4.4.4 NO NEED ANY ATF or sdc file itc... just post in Samsung General section or in you Box section....from 5.02 to 4.4.4 can do Downgrade...CANNOT from 5.1.1 "BRICK YOU PHONE" if downgrade from 5.1.1.
Here you are wrong damaging one phone that can repair just with a Wipe Factory Reset and Cache from recovery...
allumts
Old 09-02-2015, 09:34   #89 (permalink)
allumts's Avatar
Member: 1564612
Originally Posted by Rex View Post
Hi,
If phone is Sw Bricked just use only PIT and BL file in .tar.md5 format and can create by yourself Sd Card for Unbrick, read Stycky thread.
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 11-08-2015, 21:42   #90 (permalink)
Member: 2484428
i need debrick file for s4 sgh-i337 kitkat 4.4.4 please help me..
Page generated in 0.24597 seconds with 9 queries
