10-25-2012, 19:16 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: *** USA ***
Member: 97760 Status: Offline Thanks Meter: 64 | how enter code lumia 710? - SOLVED i repeat operation this log. ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 710 Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5D Product SN : 002N649D Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... WARNING: Patch Bit NOT FOUND! Maybe Phone is already UNLOCKED! Total Elapsed Time 00:02:53 |
10-26-2012, 10:31 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @alsaber Answer few questions please: 1. Is phone ask for PIN/PUK unlock code ? 2. Are you using ATF Software version 9.12 or 9.15 ? If you are already using new version of ATF Software and phone still asking for PIN/PUK code then you may need to re-flash phone to other version and unlock again via TP. BR |
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post: |
10-26-2012, 10:34 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | @WARNING: Patch Bit NOT FOUND! in simple words flash phone before unlocking and try once again to unlock it via tp |
The Following 2 Users Say Thank You to Faheem Anjum For This Useful Post: |
10-30-2012, 18:44 | #6 (permalink) |
Member: 97760 Status: Offline Thanks Meter: 64 | i have same phone, but not have signal, first not give code, i flashing phone ,unlock, and give pin 00000000 done, but not have signal, any simcard , any operator. help. thanks. |
