02-10-2014, 12:13 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | lumia 800 boot repair problem? 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V CID : 90014A48594E4958205C00DCCE90 CSD : D04F01320F5903FFFFFFFFFF8A400001 ERROR: EMMC_SEND_EXT_CSD (CMD8) Check GREEN Test Point Connection BOOT Images Written Successfully! Total Elapsed Time 00:00: I checked several times Test Point Connection is ok |
