04-10-2012, 16:39 | #2 (permalink) |
Junior Member Join Date: Sep 2008 Age: 36
Member: 871275 Status: Offline Thanks Meter: 0 | succesfull flash done Code: 14:46:30 : 14:47:41 : ================================================ 14:47:41 : Advance Turbo Flasher Found 14:47:41 : ================================================ 14:47:41 : Driver Version : 00020814 14:47:41 : Library Version : 00030204 14:47:43 : Box Type : AdvanceBox Turbo 14:47:43 : Box Firmware : LogiCore 9.02.10 14:47:43 : Software Version : v8.55 14:47:43 : AdvanceBox SN : D30B272CC6A4BB6FC8B61630 14:47:43 : Box Status : ACTIVATED 14:47:43 : ================================================ 14:47:43 : Box Successfully Initialized 14:47:43 : ================================================ 14:47:43 : 14:47:44 : VBATT Powering Down <<<< 14:47:47 : VBATT Powering Up >>>> 14:47:47 : SET VCCIO Level Done 14:47:47 : SET BSI Load Done 14:47:47 : 14:47:47 : 14:47:47 : 14:47:47 : ///////// /// /// /////// /////// ///////// 14:47:47 : /// /// /// /// // /// /// /// /// 14:47:47 : /// /// /// /////// /////// /// /// 14:47:47 : /// /// /// /// /// /// /// /// /// 14:47:47 : /// ///// /// /// /////// ////// 14:47:47 : 14:47:47 : ======================================= 14:47:47 : /// /// /// ///////// /////// ////// 14:47:47 : ///// /// /// /// /// // /// /// 14:47:47 : /// ///// /// /// /////// /// /// 14:47:47 : /// //// /// /// /// /// /// /// 14:47:47 : /// /// /// /// /// /// ////// 14:47:47 : ======================================= 14:47:47 : 14:48:58 : Make sure that you plugged the cable to the 14:48:58 : RJ-45 Port Marked << EXTENSION >> 14:48:58 : 14:48:58 : ======================================= || FLASHBUS EXTENSION || || ======= ======= || || | | |\ /| || || | | (O) (O) (O) | CABLE | || || | | |/ \| || || ======= ======= || || || ======================================= ^ ^ ^ | | | | | | PLUG IN CABLE HERE 14:49:00 : 14:49:33 : ERROR : PHONE READ INFO FAILED 14:49:33 : 14:49:56 : 14:49:56 : MCU: V 03.25 16-09-11 RH-130 (c) Nokia 14:49:56 : IMEI: 359283048951833 14:49:56 : Product Serial Number: E36E481AI 14:49:56 : Product Code : 059L4R7 14:49:57 : Module Code : 0204875 14:49:57 : Basic Production Code: 059F6X3 14:49:57 : PPM SW Version : V 03.25 16-09-11 RH-130 (c) Nokia AD 14:49:57 : ADSP Version : p V 03.25\n16-09-11\nRH-130\n(c) NMP\nad 14:49:57 : MCU SW Version : V 03.25 16-09-11 RH-130 (c) Nokia 14:49:58 : HW Version : 3051 14:49:58 : UEM Version : 1328 14:49:58 : UPP Version : 8850 14:49:58 : LCD Version : WIN:BARACOAv95 NT39121 14:49:59 : ********** SIMLOCK INFO ********** 14:49:59 : CONFIG_DATA : 0010100000000000 14:49:59 : PROFILE_BITS : 0000000000040002 14:49:59 : ASIC : 11 14:49:59 : PROVIDER : Default Test Operator 14:49:59 : 14:50:00 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 14:50:00 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 14:50:00 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 14:50:00 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 14:50:00 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 14:50:00 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 14:50:00 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 14:50:00 : ST_LCD_TEST : PASSED 14:50:00 : 14:50:09 : VBATT Powering Down <<<< 14:50:11 : VBATT Powering Up >>>> 14:50:11 : SET VCCIO Level Done 14:50:11 : SET BSI Load Done 14:50:11 : 14:50:11 : Booting Phone... 14:50:11 : CPU ID Response: A200341100 14:50:11 : CPU Type: XG110 2.1B 14:50:11 : Phone Booted at after First attempt... 14:50:11 : 14:50:11 : ****************************************************** 14:50:11 : TIME STARTS HERE 14:50:11 : ****************************************************** 14:50:11 : 14:50:12 : 14:50:12 : Sending PBL 19456 bytes... 14:50:13 : PBL Successfully Sent... 14:50:13 : 14:50:13 : Sending SBL 65024 bytes... 14:50:14 : SBL Successfully Sent... 14:50:14 : 14:50:14 : Flash Chip Manufacturer: Samsung Electronics Corp. 14:50:14 : Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR 14:50:14 : Extended Information: Multiple Bank / Burst / 1.8v 14:50:14 : 14:50:14 : Processing Image File: D:\Uni\Files\Nokia\Phoenix\Products\RH-130\rh130_003.600 14:50:14 : 14:50:14 : FIRMWARE Image Found... 14:50:14 : Number of Sections: 03 14:50:14 : FIRMWARE Certificate Block Sent Successfully... 14:50:14 : Processing Section 01 of 03 14:50:14 : FIRMWARE Erase Block: 0x00800000~0x00A0FFFE 14:50:14 : Start Erasing... 14:50:14 : Erasing Please Wait... 14:50:33 : Block Erase Done... 14:50:33 : Preparing Data Blocks... 14:50:33 : Data Size: 2162688 bytes 14:50:33 : Data Checksum: A3CA 14:50:33 : Uploading Data Blocks to phone... 14:51:03 : FIRMWARE Data Blocks uploaded to phone... 14:51:03 : Processing Section 02 of 03 14:51:03 : FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE 14:51:03 : Start Erasing... 14:51:03 : Erasing Please Wait... 14:51:24 : Block Erase Done... 14:51:24 : Preparing Data Blocks... 14:51:24 : Data Size: 2334848 bytes 14:51:24 : Data Checksum: BEE7 14:51:24 : Uploading Data Blocks to phone... 14:51:56 : FIRMWARE Data Blocks uploaded to phone... 14:51:56 : Processing Section 03 of 03 14:51:56 : FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE 14:51:56 : Start Erasing... 14:51:56 : Erasing Please Wait... 14:51:57 : Block Erase Done... 14:51:57 : Preparing Data Blocks... 14:51:57 : Data Size: 64 bytes 14:51:57 : Data Checksum: 0000 14:51:57 : Uploading Data Blocks to phone... 14:51:57 : FIRMWARE Data Blocks uploaded to phone... 14:51:57 : Start Data Verification... (Please wait) 14:52:01 : Data Verification Successful... 14:52:01 : 14:52:01 : 14:52:01 : Processing Image File: D:\Uni\Files\Nokia\Phoenix\Products\RH-130\rh130_003.60ee 14:52:01 : 14:52:01 : PPM Image Found... 14:52:01 : Number of Sections: 01 14:52:01 : PPM Certificate Block Sent Successfully... 14:52:01 : Processing Section 01 of 01 14:52:01 : PPM Erase Block: 0x00210000~0x003FF27E 14:52:01 : Start Erasing... 14:52:01 : Erasing Please Wait... 14:52:19 : Block Erase Done... 14:52:19 : Preparing Data Blocks... 14:52:19 : Data Size: 2028160 bytes 14:52:19 : Data Checksum: D122 14:52:19 : Uploading Data Blocks to phone... 14:52:47 : PPM Data Blocks uploaded to phone... 14:52:47 : Start Data Verification... (Please wait) 14:52:47 : Data Verification Successful... 14:52:47 : 14:52:47 : 14:52:47 : Processing Image File: D:\Uni\Files\Nokia\Phoenix\Products\RH-130\rh1300_nai03.60ee 14:52:47 : 14:52:47 : CONTENT Image Found... 14:52:47 : Number of Sections: 01 14:52:47 : CONTENT Certificate Block Sent Successfully... 14:52:47 : Processing Section 01 of 01 14:52:47 : CONTENT Erase Block: 0x00EB0000~0x00F0603E 14:52:47 : Start Erasing... 14:52:47 : Erasing Please Wait... 14:52:51 : Block Erase Done... 14:52:51 : Preparing Data Blocks... 14:52:51 : Data Size: 352320 bytes 14:52:51 : Data Checksum: 7651 14:52:51 : Uploading Data Blocks to phone... 14:52:56 : CONTENT Data Blocks uploaded to phone... 14:52:56 : Start Data Verification... (Please wait) 14:52:56 : Data Verification Successful... 14:52:56 : 14:52:56 : 14:52:56 : Exit Flash Mode Done... 14:52:56 : Time Elapse : 00:02:44 14:53:00 : 14:53:00 : ****************************************************** 14:53:00 : You must Factory Reset the phone to enable the 14:53:00 : ringtones and other customized settings to work 14:53:00 : ****************************************************** 14:53:00 : 14:53:00 : 14:53:00 : Waiting For Phone to go Online... 14:53:00 : 14:53:00 : 5, 14:53:00 : 4, 14:53:00 : 3, 14:53:00 : 2, 14:53:00 : 1... 14:53:01 : 14:53:01 : MCU: V 03.60 17-11-11 RH-130 (c) Nokia 14:53:01 : IMEI: 359283048951833 14:53:01 : Product Serial Number: E36E481AI 14:53:01 : Product Code : 059L4R7 14:53:01 : Module Code : 0204875 14:53:01 : Basic Production Code: 059F6X3 14:53:01 : PPM SW Version : V 03.60 17-11-11 RH-130 (c) Nokia EE 14:53:02 : ADSP Version : p V 03.60\n17-11-11\nRH-130\n(c) NMP\nee 14:53:02 : MCU SW Version : V 03.60 17-11-11 RH-130 (c) Nokia 14:53:02 : HW Version : 3051 14:53:02 : UEM Version : 1328 14:53:02 : UPP Version : 8850 14:53:02 : LCD Version : WIN:BARACOAv95 NT39121 14:53:03 : ********** SIMLOCK INFO ********** 14:53:03 : CONFIG_DATA : 0010100000000000 14:53:03 : PROFILE_BITS : 0000000000040002 14:53:04 : ASIC : 11 14:53:04 : PROVIDER : Default Test Operator 14:53:04 : 14:53:04 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 14:53:04 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 14:53:04 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 14:53:04 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 14:53:04 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 14:53:04 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 14:53:04 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 14:53:04 : ST_LCD_TEST : PASSED 14:53:04 : 14:53:05 : 14:53:05 : FACTORY SET TO : Full Factory Set 14:53:06 : OK 14:53:06 : FACTORY SET TO : User Data 14:53:06 : OK 14:53:06 : FACTORY SET TO : Leave Factory 14:53:06 : OK 14:53:06 : FACTORY SET TO : Service Center 14:53:06 : OK 14:53:06 : FACTORY SET TO : Software Upgrade 14:53:06 : OK 14:53:06 : FACTORY SET TO : Production Tune 14:53:06 : OK 14:54:57 : |
