09-04-2014, 10:14 | #3 (permalink) |
Junior Member Join Date: Jan 2013 Location: Handwara J&K
Member: 1863161 Status: Offline Sonork: 27217 Thanks Meter: 2 | Bro you should describe fully what type of help you need. For example what tool you are using to flash (UFS, ATF, UFST, BEST, MX-BOX....) and then we will help you. And also put error screen shot or text .. Thanx.. |
12-11-2014, 11:01 | #5 (permalink) |
Major Poster Join Date: Feb 2011 Location: philippines
Member: 1508116 Status: Offline Sonork: none Thanks Meter: 21 | hi sir, use usb cable (micro) for flashing, in atf sw click bb5 and choose infenion, tick usb mode,Bus check or phone scan (auto find the right unit), load mcu, ppm and cnt and then click flash and follow the software command good luck.... BR.. Last edited by joshua ontoy; 12-11-2014 at 11:08. |
