09-09-2013, 12:49 | #2 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: tuttotelefonia
Member: 125945 Status: Offline Thanks Meter: 495 | Quote:
ATF BOX SW: C:/AdvanceTurboFlashar ATF JTAG SW: C:/Program Files/AdvanceTurboFlasher For F/Bus Problem ceck that are using Good Cables, no Old f/bus cables Install the Nokia Connectivity Cable Drivers NEW, if all this not working can be Atf Sw problem, i think Team know the problem, Ready, Br Max p.d. put in Firewall exclusion, allowe Admin Access, put in Antivirus exclusion the .exe of Atf Sw, Atf Jtag, and Atf Updater | |
The Following User Says Thank You to .:Ripgsm:. For This Useful Post: |
09-09-2013, 13:20 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @bzqagh Any logs of an error you are getting on flashing or any screen shot ??? BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
09-10-2013, 16:48 | #4 (permalink) | |
Junior Member Join Date: Mar 2013
Member: 1903164 Status: Offline Thanks Meter: 0 | Quote:
but in F-bus mod the problem not solved yet all cables is good and Im flashing with UFS without problem any with same cables screenshoot | |
09-16-2013, 17:02 | #6 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
That error in your screen shot is cable problem. And things you should check: 1. Settings->Nokia Settings->FBUS VCCIO Voltage - should be checked on "Auto Detect" 2. Update Important Files 3. Your FBUS cable must be good quality, put some rubber-bands on your cable if you think is loose. BR | |
