07-23-2014, 14:36 | #1 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2076930 Status: Offline Sonork: 100.1609967 Thanks Meter: 42 | How to re alive phone? i try flash but error phone now dead condition i try same p.code flash file but same error 3 type of flash file same error no water lock no full in down please help me how to re alive phone (old codition) sorry my bad english flash log her Number of Image Files: 3 Processing Image File : rm761__12.04.mcusw Processing Image File : rm761__12.04.ppm_mh1 Processing Image File : rm761__12.04.image_mh1_059J4P6 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 127000190F0A2810 Original Product Code: 059J4P7 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354608054931706\3546080549317 06_64619.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354608054931706\3546080549317 06_CERTIFICATE_5EA4151D.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354608054931706\3546080549317 06_PMM_PROT_8F283FEB.bin Security Code: 12345 Data Sections : 04 Current File : rm761__12.04.mcusw Compile Name: rm761__12.04.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26480008 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: C1BC Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A7A Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 95E6 Uploading Data Blocks to phone... ERROR: Write Flash Failed |
07-23-2014, 16:13 | #5 (permalink) | |
Member: 2076930 Status: Offline Sonork: 100.1609967 Thanks Meter: 42 | Quote:
i asking some detaile i have some back up file C:\AdvanceBox Turbo Flasher\Nokia\Backup\354608054931706\3546080549317 06_64619.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354608054931706\3546080549317 06_CERTIFICATE_5EA4151D.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354608054931706\3546080549317 06_PMM_PROT_8F283FEB.bin rewright possible? wright possible phone come to old codition Last edited by vsy; 07-23-2014 at 16:18. | |
07-23-2014, 16:50 | #9 (permalink) | |
please connect your sonork i will contact Last edited by vsy; 07-23-2014 at 16:57. | |
07-23-2014, 17:41 | #10 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Pilipinas
Member: 1284799 Status: Offline Sonork: 100.1649097 Thanks Meter: 138 | this model is a headache. thats why i dont accept this model with hang problem. its a hardware issue and a small amount of Luck to repair it. |
07-23-2014, 22:34 | #11 (permalink) | |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Quote:
Friend you to easily solve this problem with Nokia Suite program Caire, a decided this week that the unit took to do the update and after that same mistake it made in its, could only solve the problem by updating the Nokia Suite Caire. Remember that the procedure is with the battery 100% charged. | |
The Following User Says Thank You to toninhosantos For This Useful Post: |
07-24-2014, 13:43 | #12 (permalink) | |
special thanks to toninhosantos done with Nokia Suite Caire screen shot here [IMG][/IMG] thanks to all | |
The Following User Says Thank You to vsy For This Useful Post: |
07-24-2014, 15:22 | #13 (permalink) |
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Thank you, but remember that this ATF is the best box for Nokia, there is only one such alternative procedure. Glad you got it. |
