01-27-2014, 16:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | How to read hash file Nokia 208? pls help me all user and supporter Code: 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Infineon Boot: F01650A9070100030101E01018093008057348AA8034FFFF <<<< Connect Battery Now >>>> Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Boot Successful... Unique Data: E010180930080573 Original Product Code: 059V0V4 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\358344050241181\358344050241181_100245.rpl Infineon USB Buscheck Done Phone Restart Mode: TEST MODE Process Done... Scanning USB Ports... ====================================================== ERROR: Active Phone Handle was NOT DETECTED ====================================================== TIP: Make sure that Phone USB Connection Mode is OVI Suite Mode or PC Suite Mode ====================================================== ERROR: Read Phone Failed! |
01-28-2014, 04:40 | #3 (permalink) |
Freak Poster Join Date: Aug 2012 Location: In your dreams
Member: 1802683 Status: Offline Sonork: 100.1655083 Thanks Meter: 29 | Bro first buscheck . 2nd scane phone when test mode appears . If no appear phone info then flash your phone . After flash do it which you want to do |
The Following User Says Thank You to Hotline4all For This Useful Post: |
01-28-2014, 10:14 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Click on "Decrypt XGOLD PM120 Hashes" from Imei and Locks->Simlock If ATF can't scan phone and your phone already in TEST MODE, than you need to full flash first and decrypt pm120 hashes again. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
02-03-2014, 12:31 | #5 (permalink) | |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote:
Code: Infineon Boot: F01650A9070100030101E01018093008057348AA8034FFFF <<<< Connect Battery Now >>>> Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Boot Successful... Unique Data: E010180930080573 Original Product Code: 059V0V4 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\358344050241181\358344050241181_62858.rpl Infineon USB Buscheck Done Phone Restart Mode: TEST MODE Process Done... Scanning USB Ports... ====================================================== ERROR: Active Phone Handle was NOT DETECTED ====================================================== TIP: Make sure that Phone USB Connection Mode is OVI Suite Mode or PC Suite Mode ====================================================== ERROR: Read Phone Failed! | |
02-03-2014, 17:13 | #7 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, please check on other PC, maybe your PC has some problem or make sure any other Nokia Tool/Nokia Software is not opened on PC! |
