04-28-2015, 20:57 | #2 (permalink) |
Freak Poster Join Date: Dec 2012 Location: UFI#Wellcome Worlwide UFiXers
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | This is Hynix emmc, when usb and jtag is fail, most of the problem of lumia 520 is write protected Emmc, so sorry to say, I think there are no solution for now for Hynix emmc... |
The Following User Says Thank You to madgoeslim For This Useful Post: |
04-28-2015, 21:00 | #3 (permalink) |
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | When the emmc is Samsung, write protected bug are easy to remove by ATF Jtag, You can see the thread here as example... |
05-02-2015, 12:48 | #7 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL If you have HYNIX EMMC in your 520, 525, 620, 1320 etc... And you get WP Problem, then please show logs here. I have Hynix eMMC on my phones and they never die even when I updated to 8.1 . |
The Following User Says Thank You to Advance-Box For This Useful Post: |
05-18-2015, 12:25 | #11 (permalink) |
Freak Poster Join Date: May 2009 Location: Dhaka,Bangladesh Age: 33
Member: 1032486 Status: Offline Sonork: 100.1602339 Thanks Meter: 50 | please help for hynix emmc. ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 90014A48384732640401011273746125 CSD : D02701320F5903FFFFFFFFEF8A4040D3 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7759462400 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 2048 KB eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : H8G2d Product Rev : 0.1 Product SN : 01127374 Manufactured : January 1998 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 90014A48384732640401011273746125.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ This eMMC is NOT a SAMSUNG eMMC!!! ERROR: Operation Cancelled |
