09-25-2011, 07:00 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Island Garden City Of Samal,Ph
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | HOW to reset security code FOR E6 nokia???? IMEI Plain : 354875040179555 IMEI Spare : A354875040179550 IMEI SV : 33548750401795507F Phone Model: Nokia E6-00 Product Serial Number: CDK322531 Product Code : 059D5V3 Module Code : 0204420 Basic Production Code: 0587928 Default SN Type : 0 PPM Version : V 92_11w29 20-07-11 RM-609 (c) Nokia HW Version : 7000 RFIC Version : |Alli_4.3.4 DSP Version : 92_11w29 APE BT Version : HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. AHNE Version : 11 APE SW Core Version : 024.001 APE Variant Version : 024.001024.001.07.01024.001.278.01 APE Test Version : rm609_ENO_v_0.0295 Retu Version : 40 Tahvo Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL MODE ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL MODE FACTORY SET TO : Full Factory Set FAILED FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
09-25-2011, 07:43 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @jakoy 1. Tell Customer or Owner of the the phone that all his contacts, pictures, videos etc.. will be LOST... OR Use the READ FLASH Option via USB Cable and Make a Full dump of the Flash Chip (takes 12 minutes) so that you retrieve the contacts later into a Notepad Text File. 2. Flash the Phone with UDA file only + Factory Reset The UDA File looks something like this RM-609_021.014_U03.01_79.92.uda.fpsx You should match the UDA file with the current Firmware Version... But actually, different versions will also Work Sometimes... 3. After Flashing with Factory Reset on the End... The Security Code will still say "ENCRYPTED",, but it will be "12345" already inside the Phone. 4. Extract Contacts and Other Files using the ATF 7.7x software and give the files to the owner of the Phone. B.R. |
The Following 4 Users Say Thank You to Advance-Box For This Useful Post: |
02-10-2013, 12:19 | #5 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | @ ..::Angel::.. I have an E6-00, after flashed with UDA file, the phone don't ask me the security code, I flash it just before with complete flash file (but not UDA), phone have littre error message, and restar by it self and now work fine, TKS mister ali..... Best Regards, JAVA Good. |
