Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 08-15-2014, 19:04   #1 (permalink)
mashigo's Avatar
Member: 1853465
Sonork: 100.1659145
Thanks Meter: 20
how to select files manally
pls help how to select files manually with ATF especially for phones with more than 3 files e.g E5,E72,etc pls help ATF people pls
Old 08-16-2014, 05:05   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
You can see buttons
[+MCU]
[+PPM]
[+CNT]
etc...
use them
Old 08-16-2014, 06:12   #3 (permalink)
mashigo's Avatar
Member: 1853465
Sonork: 100.1659145
Thanks Meter: 20
clearly u dont understand my problem,pls read it clearly and give me the right answer i knw how to select mcu,ppm and image but what if the are more files like e5 files ,how do u select them step by step can u explain or someone who knws best can pls explain thanx in advance
Old 08-16-2014, 07:13   #4 (permalink)
Member: 651945
@mashigo
Technically speaking, +MCU, +PPM, +CNT does the same thing... even if you select PPM file when you click +MCU, ATF will accept it.
SO if you want to add more files for E5 etc, just click +CNT few more times until all files are loaded.
But the best way would be to always use VPL files.
In fact, you can download Nokia Flash Files 100% FREE if you know the product code of the phone.
Check it here:
http://forum.gsmhosting.com/vbb/f609...added-1660094/
So again, safest way is always to flash phone using VPL files, so all required flash files will be checked against CRC32 errors.
Old 08-16-2014, 08:20   #5 (permalink)
imraan ali's Avatar
Member: 2023768
Sonork: 100.1661054
Thanks Meter: 76
if the files are more then 3
then your files name will be not mcu ppm cnt
name will like this prd.core.fpsx
rofs2 rofs3 and uda
now first you choos core file which is also have large size then other
2nd in ppm section choos rofs2 and in cnt section choos uda file
these three file is enough for many mobiles
but in some mobile you will be need rofs3 file
in this case first file core 2nd rofs2 3thrd rofs3 and 4 num uda
Old 08-16-2014, 08:31   #6 (permalink)
imraan ali's Avatar
Member: 2023768
Sonork: 100.1661054
Thanks Meter: 76
but i give you best soluation
download full flash file from navifirm
and in atf make a prudect path
where you want
and copy all the file in a folder and paste there
but your folder name must be like this
for example if you have rm 607 file
make a folder RM-607 and copy all the file in this folder
and paste this folder to prudect path
and in atf work as phonix file
this is easy and better atf will also check your flash file
before flash and will tell you files are good are corrept
The Following User Says Thank You to imraan ali For This Useful Post:
Page generated in 0.14677 seconds with 8 queries
