How to solve this VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: D:\Program Files\Nokia\Phoenix\Products\RH-125\rh125_006.200 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 507C Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2136128 bytes Data Checksum: FD7E Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: D:\Program Files\Nokia\Phoenix\Products\RH-125\rh125_006.20ed PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x0044337E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2306944 bytes Data Checksum: 5AEB Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: D:\Program Files\Nokia\Phoenix\Products\RH-125\rh1250_nai06.20ed CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00F02D7E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 339328 bytes Data Checksum: 05EF Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:02:43 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 06.20 01-12-10 RH-125 (c) Nokia IMEI: 358632045245717 Product Serial Number: C28A7A1AI Product Code : 0595840 Module Code : 0204343 Basic Production Code: 059F8R0 BT MCM Version : V 06.20 01-12-10 RH-125 (c) Nokia ED AEM Version : p V 06.20\n01-12-10\nRH-125\n(c) NMP\ned HW Version : V 06.20 01-12-10 RH-125 (c) Nokia PCI Version : 1013 UPP Version : 1328 RFIC Version : 8850 Camera : WIN:BAFFINv80 NT39121 ********** SIMLOCK INFO ********** ERROR : Unable to read Simlock Info ... Maybe you are reading BB5 phone ... ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK PHONE status dead |
maybe try this post http://forum.gsmhosting.com/vbb/f609...hones-1497095/ |
i think you have selected bb5 series,select infineon and you extension port |
The above mention process work if SL data corrupted when reset counter @ kathirmobiles Not possible to repair SL data at now Br - srinibas |
1 Attachment(s) http://forum.gsmhosting.com/vbb/atta...1&d=1342190886 kathirmobiles did you notice you log i have highlight it the is saying(Maybe you are reading BB5 phone ...) |
thanks for all reply mempers |
