12-05-2013, 19:46 | #1 (permalink) |
Product Supporter Join Date: Nov 2006 Location: Ecuador, Shenzhen, Guangzhou Age: 55
Member: 394446 Status: Offline Sonork: 100.1579789 Thanks Meter: 74 | how to unlock lumia using jtag |
12-06-2013, 05:29 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | Hi Bro, Try using V2 Unlock AFP here: http://174.120.45.27/tmp/610_610C_51..._UNLOCK_V2.rar Then follow instructions here: 1. Disconnect USB Cable from your Phone. If you verified JTAG connection more that 3 times, then it should be 100% OK. However, how long are your wires? Your wires should be less than 4 inches in total from phone PCB to ATF Box Port. Also, use old FBUS cables for RJ-45 Connection. Do not use PC LAN RJ-45 Patch Cable because the wire impedance is out of range. 2. Open Windows Device Manger ---> Here you will see "Human Interface Devices", expand it to see the currently connected HIDs. Now Connect USB cable to phone: ---> Phone Should NOT HAVE BATTERY ---> Phone Should already be connected to ATF Box 3. Wait until you will see a new Device in "Human Interface Devices". Normally, this device will come up 15 seconds after the phone vibrates. The Device name is "USB Input Device" When you see the new "USB Input Device" come up, Disconnect the USB cable from the phone. *** "USB Input Device" will only be there for about 5 seconds. If it disappears before you were able to Disconnect the USB cable, then you should start again from Step 1. *** 4. Click "READ CODES" or "RESTORE BOOT" button... then connect USB Cable to Phone. It should be able to read the unlock codes now. *** What to do if it is still not working ??? *** a. Make sure your PC can Flash Lumia WP7 Phones because this means all Lumia required drivers are installed properly. b. Make sure your phone is not dead. Make sure it can still power up properly with Battery even when JTAG wires are connected to the ATF Box. c. Make sure you are using JTAG TP and NOT eMMC TP. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
