Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-17-2012, 15:54   #1 (permalink)
Member: 1529968
Thanks Meter: 23
how to unlock nokia 6500s [SOLVED]
sir i m new user atf .plz give me info
6500S cannot be unlock‎??????
Old 04-17-2012, 15:57   #2 (permalink)
Member: 1450664
Thanks Meter: 163
post log here sir. 6500s is sl2 go sim lock sec. and press direct unlock
Old 04-17-2012, 16:04   #3 (permalink)
Member: 1529968
Thanks Meter: 23
Scanning USB Ports...
Basic Phone Information
MCU Version: V 04.81 22-11-07 RM-240 (c) Nokia
IMEI Plain : 353077021316105
IMEI Spare : A353077021316100
IMEI SV : 33530770213161016F
Phone Model: Nokia 6500s-1
Category : Connect Phone
Phone Type : RM-240
Extended Phone Information
Product Serial Number: KUA118821
Product Code : 0555552
Module Code : 0203327
Basic Production Code: 0543753
Long Production SN : 0
PPM SW Version : V 04.81 22-11-07 RM-240 (c) Nokia C
BT MCM Version : 2222-101B
MCU SW Version : V 04.81 22-11-07 RM-240 (c) Nokia
HW Version : 2000
RFIC Version : 17141715
DSP Version : ICPR71_07w43
LCD Version : SHARP
Content Pack Version : Content: c_uk V 04.81 22-11-07 RM-240 (c) Nokia
AHNE Version : 30
RETU Version : 15
TAHVO Version : 22
Bluetooth ID : 00:1F:5C:88:49:1A
CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA V
Simlock Information
CONFIG KEY : 8000000000000002
PROVIDER KEY : 2342000000000000
NETWORK NAME : Hutchison 3G UK Ltd;UK [GSM]
LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
SIMLOCK TABLE :
Block [1] 1:Close
Block [2] 1:Close
SIMLOCK STATE : LOCKED
SIMLOCK_TYPE : PA_SL2
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
PHONE_MODE : NORMAL
Make sure you have installed the
COMPLETE Flash Package for this Phone...
Goto "Settings" --> "Nokia Settings" and verify that
the Folder where you installed your Flash Files are
in the "PRODUCT PATH TO SCAN" List...
*** WARNING ** WARNING ** WARNING ** WARNING ***
DO NOT USE FIRMWARE VERSION 5x.xx if your Phone
does not have SL3 Type Simlocks and Security!!!
Examples of SL3 Firmwares:
v56.26, v57.23, v57.20, v58.58, v59.42, v59.60
Phone Type : RM-240
HW Version : 2000
LCD Version : SHARP
AHNE Version : 30
RETU Version : 15
TAHVO Version : 22
Simlock Information
SIMLOCK TABLE :
Block [1] 1:Close
Block [2] 1:Close
PHONE_MODE : NORMAL
Old 04-17-2012, 16:07   #4 (permalink)
.::MD_AKTER::.'s Avatar
Member: 552244
Sonork: 100.1578827
Thanks Meter: 179
If yuor phone lock status is Sl3, Then try with lbf. Free unlocking only Sl2 phone.
Old 04-17-2012, 16:09   #5 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,528
@Gsmpages
Your phone is SL2 catagory. Do this:
Go to IMEI and Locks tab -> SIMLock -> Direct Unlock (SL1/SL2).
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 04-17-2012, 16:09   #6 (permalink)
Member: 1450664
Thanks Meter: 163
send here team id i,l be solve your problm sir
Old 04-17-2012, 16:11   #7 (permalink)
Member: 552244
Sonork: 100.1578827
Thanks Meter: 179
Phone Type : RM-240
HW Version : 2000
LCD Version : SHARP
AHNE Version : 30
RETU Version : 15
TAHVO Version : 22
Simlock Information
SIMLOCK TABLE :
Block [1] 1:Close
Block [2] 1:Close
PHONE_MODE : NORMAL
Phone Type : RM-240
HW Version : 2000
LCD Version : SHARP
AHNE Version : 30
RETU Version : 15
TAHVO Version : 22
Simlock Information
SIMLOCK TABLE :
Block [1] 1:Close
Block [2] 1:Close
PHONE_MODE : NORMAL
Simply press direct unlock to unlock it.
Old 04-17-2012, 17:26   #8 (permalink)
Member: 1529968
Thanks Meter: 23
Originally Posted by ..::Angel::.. View Post
@Gsmpages
sir angel...........
this is problem
ERROR: Phone is NOT AUTHORIZED!
Old 04-17-2012, 17:34   #9 (permalink)
Member: 643472
Sonork: 100.96901
this is problem
Use FBUS my bro. NOT USB cable
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 07-08-2017, 04:10   #10 (permalink)
Member: 2734424
please need help unlocking mine
Old 07-09-2017, 21:26   #11 (permalink)
Member: 2693563
Thanks Meter: 5
you need the fbus cable to unlock this phone the usb cable wont work
for most nokia phones need a fbus cable to unlock
reading the log it is a sl2 firmware so you can unlock it but you need the cable
a fbus cable is a cable with rj45 connector on one end and small black box with gold pins
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.34932 seconds with 8 queries
