Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 12-31-2013, 18:40   #1 (permalink)
Member: 1931004
Sonork: 100.1662382
Thanks Meter: 85
Unhappy Cant Flash C2-00
I have a Nokia C2-00 RM-704, the phone cant boot up; when trying to turn it on it will just light up and shutdown without showing Nokia Logo.
I try to flash it with ATF+Usb but not successful, i follow the exact step below:
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (doesnt boot automatically)
4. Power on phone shortly...
But it will just light up and shutdown without showing Nokia Logo.
See the Screenshot Below:
What do you think is wrong ?
Please need your Help...
Old 12-31-2013, 18:55   #2 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
Down in the program i see "BOX_FBUS_MODE" and you try to flash it via USB...
Set program to USB communication or try to use f-bus cable.
Old 12-31-2013, 21:08   #3 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
OK. I see it, you ticked USB MODE so it should work,
Do you hear usb conecting da-di when connecting the phone?
If yes - check in Device Manager if you have properly installed drivers.
It's about Nokia Connectivity Cable Driver.
Old 01-01-2014, 06:21   #4 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
@ - binadam23
Check driver , connector & cable
Br - srinibas
Old 01-01-2014, 11:32   #5 (permalink)
Member: 1931004
Sonork: 100.1662382
Thanks Meter: 85
I didn't hear a usb connecting sound. and i have nokia connectivity cable driver installed and ok.
Old 01-01-2014, 11:35   #6 (permalink)
Member: 1931004
Sonork: 100.1662382
Thanks Meter: 85
Originally Posted by srinibas View Post
@ - binadam23
Br - srinibas
Driver & Cable are OK, but i dont know about the connector. Or is there a way i can detect if the connector have any fault..?
Old 01-01-2014, 12:34   #7 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Connector means USB socket of phone
Br - srinibas
Page generated in 0.15609 seconds with 8 queries
