07-11-2014, 17:50 | #1 (permalink) |
Junior Member Join Date: Nov 2010 Location: ukraine
Member: 1449823 Status: Offline Thanks Meter: 9 | i have work hynix H9DP32A4JJAC does not want to read but samsung chip good work Code: eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 0 KB USER AREA SIZE : 134217728 BYTES BOOT PARTITION SIZE: 0 KB RPMB PARTITION SIZE: 0 KB eMMC Device Information Manufacturer ID: 65 Device Type : Removable Card Application ID : 6F Product Name : M MOR Product Rev : 0.0 Product SN : 00000000 Manufactured : January 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes WP_GRP_ENABLE : NO WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 65646F4D204D4F52000000000000_2901782A.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Code: eMMC Boot Information 17:57:17 : Revision 1.5 (for MMC v4.41) 17:57:17 : BOOT PARTITION : NOT BOOT ENABLED 17:57:17 : PARTITION ACCESS : R/W USER PARTITION 17:57:17 : PERM_BOOT_CFG_PROT : DISABLED 17:57:17 : PWR_BOOT_CFG_PROT : DISABLED 17:57:17 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 17:57:17 : RESET BUS WIDTH : ENABLED 17:57:17 : eMMC FirmW UPDATE : DISABLED 17:57:17 : EMMC CACHE SIZE : 0 KB 17:57:17 : SUPER PAGE SIZE : 3584 KB 17:57:17 : HC ERASE GROUP SIZE: 512 KB 17:57:17 : USER AREA SIZE : 15758000128 BYTES 17:57:17 : BOOT PARTITION SIZE: 512 KB 17:57:17 : RPMB PARTITION SIZE: 128 KB 17:57:17 : 17:57:17 : 17:57:17 : eMMC Device Information 17:57:17 : Manufacturer ID: SAMSUNG 17:57:17 : Device Type : Embedded BGA 17:57:17 : Application ID : 00 17:57:17 : Product Name : KYL00M 17:57:17 : Product Rev : 2.0 17:57:17 : Product SN : 62AB2BE5 17:57:17 : Manufactured : January 2011 17:57:17 : 17:57:17 : Card Specific Data 17:57:17 : CSD_STRUCTURE : Extended 17:57:17 : SPEC_VERS : Version 4.1/4.2/4.3 17:57:17 : TAAC : 13 ns 17:57:17 : TRANS_SPEED : 4000000 KHz 17:57:17 : READ_BL_LEN : 512 Bytes 17:57:17 : C_SIZE : HIGH CAPACITY 17:57:17 : WP_GRP_ENABLE : YES 17:57:17 : WRITE_BL_LEN : 512 Bytes 17:57:17 : CONTENT_PROT_APP : NO 17:57:17 : PERM_WRITE_PROTECT: NO 17:57:17 : TMP_WRITE_PROTECT : NO 17:57:17 : 17:57:17 : Extended CSD Saved: 17:57:17 : 1501004B594C30304D2062AB2BE5_13A22803.ext_csd 17:57:17 : Backup Directory: 17:57:17 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
