02-28-2017, 16:40 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Romania Age: 48
Member: 52722 Status: Offline Thanks Meter: 18 | I must to activate the ATF.. pls help Now i reinstal atf and I must activated... but... dont work Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : EB6CA333F5BD6596CCE60AE6 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done PLS HELP BR Mihnea |
The Following User Says Thank You to Mihnea For This Useful Post: |
02-28-2017, 18:41 | #3 (permalink) |
Major Poster Join Date: Nov 2012
Member: 1842752 Status: Offline Thanks Meter: 18 | Atf software is not activated on this pc ATF SOFTWARE IS NOT ACTIVATED ON THIS PC now re instal pc atf problem activation help me |
The Following User Says Thank You to mtk_6235 For This Useful Post: |
02-28-2017, 20:33 | #4 (permalink) |
Insane Poster Join Date: Jun 2014 Location: Hospitle Age: 36
Member: 2203193 Status: Offline Thanks Meter: 28 | Check this post http://forum.gsmhosting.com/vbb/f609...rolem-2198082/ |
03-01-2017, 10:00 | #6 (permalink) | |
Freak Poster Join Date: Feb 2002 Location: Gemany Age: 41
Member: 9493 Status: Offline Thanks Meter: 9 | ... Quote:
03-01-2017, 10:24 | #7 (permalink) |
Major Poster Join Date: Jul 2002
Member: 13537 Status: Offline Thanks Meter: 5 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : CA0F9FC486A67C45A3C8573E ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-01-2017, 11:58 | #13 (permalink) | |
Are You sure activation Server is up and running? Can You check if there is a activation request comming in? I could pm you my ATF Serial number | |
03-01-2017, 17:57 | #14 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Đà Nẵng - Việ Age: 44
Member: 1911593 Status: Offline Sonork: 100.1645151 Thanks Meter: 130 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : 7ABE1110448A399F7DA9E5AE ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-01-2017, 17:59 | #15 (permalink) |
Member: 52722 Status: Offline Thanks Meter: 18 | I instal atf fuul installer 12.60 to other pc, clean pc.... I see that UPDATE IMPORTANT FILES, and CHECK SOFTWARE UPDATES....FROM Product Support -- works But ACTIVATE ATF... Dont works..... BR Mihnea |
