10-30-2014, 10:16 | #16 (permalink) | |
Freak Poster Join Date: Mar 2013
Member: 1893471 Status: Offline Thanks Meter: 25 | Quote:
thanks, I do following steps I put card in phone and power on it in download mode remove sd card from phone put these files of v 4.3 in odin D2_USA_ATT_16G.pit BL_I747UCUEMJB_2024954_REV04_user_low_ship.tar.md5 uncheck repartition in odin press flash and failed also failed with check mark on repartition here are logs <ID:0/023> DO NOT TURN OFF TARGET!! <ID:0/023> Get PIT for mapping.. <ID:0/023> Firmware update start.. <ID:0/023> SingleDownload. <ID:0/023> sbl1.mbn <ID:0/023> NAND Write Start!! <ID:0/023> sbl2.mbn <ID:0/023> sbl3.mbn <ID:0/023> aboot.mbn <ID:0/023> FAIL! (Auth) <ID:0/023> <ID:0/023> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) any suggestion? Last edited by teetopati; 10-30-2014 at 10:21. | |
10-30-2014, 11:07 | #17 (permalink) | |||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
10-30-2014, 11:59 | #20 (permalink) | |
If yes, READ CAREFULLY, try to flash One package only, (same that had success with sd card in the phone), Boot phone in D.Mode with Sd Card, FIRST of flash one package fw, get out the Sd Card and Flash phone. Post here Odin Log, use 3.09 odin | |
10-30-2014, 12:08 | #21 (permalink) | |
You need to use ALWAYS same FW and same BL of the Fw that has used for make Sd Card. Example, if you had used 4.3 fw and sdc file for 4.3 you must need obbligatory of flash Same FW 4.3 and same version of the Sdc file. You cannot do how you want. I had advised you of use sdc file 4.4.2 but you non listen and not read.... NOTE: Wait my answer first or post all in one what you do, i've answer right with my doubt about BL you have used. | |
10-30-2014, 12:27 | #22 (permalink) |
Member: 1893471 Status: Offline Thanks Meter: 25 | History is here after brick I use 4.3 debrick image but could not get power on. I follow your advice to use sdc file 4.4.2, this tip work and my phone get into dm successfully later I flash 3 files of version 4.3 without pit and bootloder, this help me to power on phone complete But no power on phone without sd card. next step was flashing with pit and bootloader of 4.3 (as per your advice)but result in failure. I thought that as I used sdc file 4.4.2 so may be bootloader update to 4.4.2 I decided to update it 4.4.2 with the the help of TWRP it updated successfully but problem is same no boot without sd card and bootloader is obviously 4.4.2 now waiting for your reply I could not find 4.3 in 1 file, either it is in zip format to flash through recovery or these 3 files. |
10-30-2014, 13:31 | #23 (permalink) | |||||
2° you have flashed with Sd Card inside the phone it's wrong, never do this after reboot in D.Mode. Quote:
In this mode you'll have solved easy w/o issue. Now you, FIRST of do anythyngh write exactament what you do, after Post Full description of the FW that use and LOG/s. Now i not know what mistake have done with this TWRP, please, if you can, Elimine this TWRP. Boot phone in D.Mode with Sd Card and Flash Only PIT+BL of SAME FW Version of the Sdc file, 4.4.2 NO OTHER, but NOT FORGOT of get out the Card first of the Flash. FORGOT 4.3 If this Pass, after Flash Full Fw one package 4.4.2 same version of the card no OTHER. Or if FAIL also this try Flash directly One Package Fw 4.4.2 SAME version of the Sdc file but W/O Sd Card. If not have understand algo, please first of do anythyng ASK, becouse Never I knew you was working with 4.4.2 fw and sdc file. BR | |||||
The Following User Says Thank You to allumts For This Useful Post: |
10-30-2014, 15:35 | #24 (permalink) | |
Only we can update from 4.3 to 4.4.2 via twrp | |
10-30-2014, 15:44 | #25 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | No, you must need od search and Find BL for this same version of Fw no other no zip or with TWRP, only Odin flashable. Search in Samsung Fw section, or try to make 4 part file from one package, it's easy thre's all procedure, but i'm sure that you can find, sorry but now is time that you solve this BL file from yourself, after i can help you Br allumts |
10-30-2014, 16:11 | #26 (permalink) |
Member: 1893471 Status: Offline Thanks Meter: 25 | I think here is some of our interest, pls check and verify [Modem][Baseband]4.4.2 Modems for I747/I747M | AT&T, Rogers, Bell, Telus Samsung Galaxy S III | XDA Forums |
10-30-2014, 17:05 | #28 (permalink) |
Member: 1893471 Status: Offline Thanks Meter: 25 | @Angel I don't know why there is no Thanks button under you post, but I am really thankful to you by heart for this sharing, Today you seem like a real Angel @allumts I recover my phone by your instructions. First I flash Angel's files, than I boot into recovery later I flash 4.4.2 OTA zip file via TWRP yes TWRP because there is no other way as 4.4.2 not available in 1 package file than I flash stock recovery in Twrp and reboot , phones alive, hurraaaaaaaaaah It take my 7 days for this success and I have no words to say thanks both of you for your time ,care, and support, except prayers from my heart because my feelings cannot express in the words, *** bless you and have more more and more success in this life and after this, thanks again |
The Following User Says Thank You to teetopati For This Useful Post: |
10-30-2014, 20:31 | #29 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @teetopati, i leave thanks to you becouse at the end have listen me. But only one thingh, BL +PIT posted by @Angel is in .Tar format, so in Odin flashable mode, so not have any issues and no need you TWRP recovery, just Flash with odin BL and "UNCECK" repartition when add PIT file. Good lucky BR allumts |
