05-28-2015, 15:28 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Romania Buzau Age: 54
Member: 14468 Status: Offline Thanks Meter: 50 | I8160 repair boot This is log with ATF direct EMMC. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 45010053454D30344730E08A08AFB0CF CSD : D00F00320F5903FFFFFFFDFF8A4040A7 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 2048 KB USER AREA SIZE : 3959422976 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 2048 KB eMMC Device Information Manufacturer ID: SANDISK Device Type : Embedded BGA Application ID : 00 Product Name : SEM04G Product Rev : 3.0 Product SN : E08A08AF Manufactured : November 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 45010053454D30344730E08A08AFB0CF.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Thank you! best regards vali |
05-31-2015, 10:58 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | You can normal write BL_I8160XXXXXXX.tar.md5 (Only BL) or I8160XXXXXXXXX_HOME.tar.md5 (full firmware). BR |
The Following 3 Users Say Thank You to ..::Angel::.. For This Useful Post: |
