12-07-2016, 17:31 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Age: 40
Member: 2304141 Status: Offline Sonork: 100.22932 Thanks Meter: 31 | i8190 derct emmc . DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC IS NOT Ready! (CMD1) Try to Adjust VCCIO Voltage CMD1 Reply: 0x00FF8080 WARNING: POSSIBLE eMMC is TOTALLY DEAD!!! Interface Reset OK! eMMC Access Type is BYTE MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V ERROR: EMMC_ALL_SEND_CID FAILED (CMD2) Check your Test Point Soldering! Try to Adjust VCCIO Voltage and post me corect pin out plez |
