01-30-2015, 18:43 | #6 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | @anwar.welltech Hi, It is the same. Tested Pinouts: Take note of SMALL TP Pads which I show that needs to be connected to Ground. Now Connect with ATF RJ-45 For Boot Files, I still need to make it for you. Just Try to connect eMMC first and dump BOOT1 + BOOT2 (32MB each) and USER Partition 512 MB for backup purposes. Only use correct 1.80V and 3.30V external power supply. Using other voltages will not work properly. If eMMC is hard to be detected by ATF Software, just disconnect RJ-45 Cable and try again. Once connection is established, you will be able to dump properly. B.R. |
The Following 4 Users Say Thank You to Advance-Box For This Useful Post: |
02-19-2015, 14:45 | #8 (permalink) |
No Life Poster Join Date: Apr 2004
Member: 61389 Status: Offline Thanks Meter: 193 | Hi i was tested with atf and easyjtag both not working Easy: Can't init EMMC, Reason: CMD Timeout Error ATF: Establishing connection...... The brown tp between the proc and the emmc connected to the ground and all soldering fine and triple checked. Made by me under microscope |
04-07-2015, 10:26 | #9 (permalink) |
Freak Poster Join Date: Mar 2002 Age: 46
Member: 10011 Status: Offline Thanks Meter: 46 | Hello. I have a dead i8200n (killed by me with wrong flash and pit file, now recognised via USB as EMEI), and was wondering if boot files (.mmc) are available for this model? Br d3m0n |
05-22-2015, 11:00 | #12 (permalink) | ||
Member: 10011 Status: Offline Thanks Meter: 46 | Quote:
br d3m0n | ||
The Following User Says Thank You to demon For This Useful Post: |
05-22-2015, 13:01 | #13 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Turkey
Member: 1169259 Status: Offline Sonork: 100.1648194 Thanks Meter: 149 | Quote:
****************************/folder/p4t...rl08jbr/shared | |
The Following User Says Thank You to mhammadleo For This Useful Post: |
05-28-2015, 09:24 | #14 (permalink) | |
Is there a way to convert those that you linked int .mmc? | |
