01-14-2016, 22:06 | #16 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO |
01-14-2016, 22:10 | #17 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : K7XVMB Product Rev : 0.1 Product SN : D76FD84A Manufactured : January 1998 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO |
05-03-2016, 14:36 | #19 (permalink) |
No Life Poster Join Date: Jan 2014 Location: india
Member: 2097870 Status: Offline Sonork: FINDING.... Thanks Meter: 65 | i9060/ds odin full flash but kies online update this phone but phone phone still on stuck on firmware update encountered atf jtag how to emmc write file and my sol problem plzz sol here this problem |
05-22-2016, 12:01 | #21 (permalink) |
No Life Poster Join Date: Nov 2003
Member: 44904 Status: Offline Thanks Meter: 45 | need B1 B1 UA for i9192 i format emmc DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D384732464200760090C83041 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.6 (for MMC v4.5, v4.51) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : ENABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 2048 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2FB Product Rev : 0.0 Product SN : 760090C8 Manufactured : March 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D384732464200760090C83041.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
05-22-2016, 12:05 | #22 (permalink) |
Member: 44904 Status: Offline Thanks Meter: 45 | error update firmware emmc Task Selected: Samsung eMMC Firmware Update ================================================== ==== --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB --> This will RESET EXT_CSD Programming Such as BOOT Options, Bus Characteristics and Partition Sizes.. ================================================== ==== Please Manually Select the Correct Part Number of your eMMC Device. ================================================== ==== If you select a WRONG PART NUMBER, then YOU WILL PROBABLY KILL THE EMMC !!! ================================================== ==== ================================================== ==== Loading ATF eMMC Firmware File... (Please Wait) ================================================== ==== File Author: ATF Team @ SmartGSM Date Created: 18/06/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KLM8G2FE3B-B001 eMMC Product Name: M8G2FB eMMC Product Rev: 0.3 Preparing eMMC for Firmware Update... R1b Timeout Error! ERROR: CUSTOM_VENDOR_COMMAND FAILED 0x03 Total Elapsed Time 00:00:06 |
05-28-2016, 04:08 | #24 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Quote:
i need pinout for repair direct emmc my handset id dead condition but i cant find test pin out please help me bro | |
09-27-2016, 06:48 | #25 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004B3758564D4203C510CCC121F7 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.6 (for MMC v4.5, v4.51) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3072 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : K7XVMB Product Rev : 0.3 Product SN : C510CCC1 Manufactured : January 1998 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004B3758564D4203C510CCC121F7.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
