06-24-2016, 21:39 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | i9192 cant repair Samsung i9192 dont power I made resurrection by RIFF but still no power Phone detects as Qualcomm QDloader 9008 Now flashed with ATF: -select "User Area" -press "Write" -select "I9192XXUCOA1_I9192OXECOA1_I9192XXUCOA1_HOME.tar.m d5" (Nonhloss and boot files was checked auto) Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D414732474300FF1165AC60B9 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : MAG2GC Product Rev : 0.0 Product SN : FF1165AC Manufactured : June 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D414732474300FF1165AC60B9.ext_csd Backup Directory: D:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: non-hlos.bin Start Writing 0x0001E000 Blocks at 0x00002000 Partition Selected: USER AREA Write Block Error Total Elapsed Time 00:22:52 ERROR: Write FAILED! Flash Image: aboot.mbn Start Writing 0x00001000 Blocks at 0x00020700 Partition Selected: USER AREA Total Elapsed Time 00:00:34 Write Success! Flash Image: sbl2.mbn Start Writing 0x00000200 Blocks at 0x00020100 Partition Selected: USER AREA Total Elapsed Time 00:00:08 Write Success! Flash Image: sbl3.mbn Start Writing 0x00000400 Blocks at 0x00020300 Partition Selected: USER AREA Total Elapsed Time 00:00:11 Write Success! Flash Image: rpm.mbn Start Writing 0x00000400 Blocks at 0x00021700 Partition Selected: USER AREA Total Elapsed Time 00:00:03 Write Success! Flash Image: tz.mbn Start Writing 0x00000400 Blocks at 0x00021B00 Partition Selected: USER AREA Total Elapsed Time 00:00:08 Write Success! Total Images Written: 5 Process Done! Are these steps correct? What UserData should i use for reviwe? Thanx |
06-28-2016, 10:04 | #3 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | I write boot from 4-file firmware and ext_csd backup Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D414732474300FF1165AC60B9 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : MAG2GC Product Rev : 0.0 Product SN : FF1165AC Manufactured : June 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D414732474300FF1165AC60B9.ext_csd Backup Directory: D:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ MBR is Corrupted... Start Writing Flash Images... Flash Image: MBR + PGPT Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: PIT Start Writing 0x00000008 Blocks at 0x00000022 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: SGPT Start Writing 0x00000021 Blocks at 0x01D59FDF Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: sbl1.mbn Start Writing 0x00000100 Blocks at 0x00020000 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: sbl2.mbn Start Writing 0x00000200 Blocks at 0x00020100 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: sbl3.mbn Start Writing 0x00000400 Blocks at 0x00020300 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: aboot.mbn Start Writing 0x00001000 Blocks at 0x00020700 Partition Selected: USER AREA Total Elapsed Time 00:00:06 Write Success! Flash Image: rpm.mbn Start Writing 0x00000400 Blocks at 0x00021700 Partition Selected: USER AREA Total Elapsed Time 00:00:03 Write Success! Flash Image: tz.mbn Start Writing 0x00000400 Blocks at 0x00021B00 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Total Images Written: 6 Process Done! |
