01-26-2016, 02:06 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | I9192 only restart ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 45010053454D30384790F09B22699009 CSD : D00F00320F5903FFFFFFFFFF92404011 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : ENABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3072 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SANDISK Device Type : Embedded BGA Application ID : 00 Product Name : SEM08G Product Rev : 9.0 Product SN : F09B2269 Manufactured : September 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 45010053454D30384790F09B22699009.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
01-26-2016, 08:30 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Check power key button, can are in short |
The Following User Says Thank You to toninhosantos For This Useful Post: |
01-26-2016, 12:15 | #3 (permalink) | |
Freak Poster Join Date: Jun 2012 Location: bali
Member: 1778254 Status: Offline Sonork: sornork id Thanks Meter: 36 | Quote:
try chang eMMC using s3 eMMC | |
