04-21-2014, 14:35 | #1 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,707 | i9300 dead boot repaired success with ATF yesterday i had repaired one I9300 with ATF JTAG successfully with less than 5 min here u are the log: Code: 09:44:21 : SDC Direct Access Connection Module 09:44:21 : ====================================================== 09:44:21 : ====================================================== 09:44:21 : 09:44:23 : Card Reset Done! 09:44:23 : Initializing Micro SD Card... 09:44:23 : Card Initialized OK (V2.0 Compliant) 09:44:23 : Waiting for IDLE State... 09:44:23 : Card is now IDLE! 09:44:23 : 09:44:23 : Reading Micro SD Card Information... 09:44:23 : Manufacturer ID : 0x12 09:44:23 : Application ID : 4V 09:44:23 : Product Name : MS 09:44:23 : Product Revision : 0.0 09:44:23 : Serial Number : 0000074B 09:44:23 : Manufacture Date: October 2013 09:44:23 : 09:44:23 : Card CID: 1234564D53000000000000074B00DAE5 09:44:23 : Card CSD: 400E00325B5900003B877F800A4000C7 09:44:23 : Card SCR: 02B5000000000000 09:44:23 : Card OCR: 00C0FF8000 09:44:23 : 09:44:23 : SD Card Size : 7990149120 Bytes 09:44:23 : SD Block Size: 512 Bytes 09:44:23 : Maximum Speed: 25000000 Hertz 09:44:23 : 09:44:23 : SDHC / SDXC Card Detected... 09:44:23 : Checking Lock Status... 09:44:23 : Micro SD Card is NOT Password Protected!!! 09:44:23 : 09:44:23 : Erasing SDC... 09:44:39 : Samsung GT-I9300, I9500, N7100 UNBRICK Image 09:44:39 : Start Writing to SDC at 0x00000000... 09:44:39 : Number of Blocks: 0x0002B055 09:45:55 : 09:45:55 : Process Done... 09:45:55 : 09:45:55 : ====================================================== 09:45:55 : 1. Insert Micro SD Card to Phone 2. Make Sure Battery is Fully Charged 3. Connect UART Cable (150K Resistor) 4. Wait upto 5 Minutes... 5. Remove Battery and Remove Micro SD Card 6. Flash Phone with ODIN 09:45:55 : ====================================================== 09:45:55 : Total Elapsed Time 00:01:39 09:45:55 : Write Success! after repairing the boot zone the phone must be flashed with 4 parts firmware(full firmware) I used 4.3 version... b.r. |
The Following 3 Users Say Thank You to bk.gsm For This Useful Post: |
04-21-2014, 21:55 | #11 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,707 | http://forum.gsmhosting.com/vbb/f609...ng-s3-1775463/ here u can find all the answers....just watch the video... B.r. |
