07-18-2014, 13:43 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | I9300 direct emmc boot repair issue <<< SOLVED >>> Today i have come one Samsung i9300 which is automatically dead i will try to repair boot with Mmc method not work than i will try TP mmc method its also not work After that try with direct emmc method connection OK But just hang on any Oparaction not erased not write etc ... Here is the error log Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 1.45-1.50V CID : 15010056545530304DF159A77732 CSD : D02701320F5903FFF6DBFFFF8E40406D eMMC Boot Information Revision 1.6 (for MMC v4.5) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : VTU00M Product Rev : 15.1 Product SN : 59A77732 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010056545530304DF159A77732_932DD6C7.ext_csd Backup Directory: G:\All Software Box\A T F\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Normal Factory Erase ====================================================== For eMMC Revision 1.2 (for MMC v4.2) and LOWER --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB For eMMC Revision 1.3 (for MMC v4.3) and HIGHER --> This will ONLY ERASE USER AREA ====================================================== This eMMC is: Revision 1.6 (for MMC v4.5) Factory Erasing Supported FLASH AREA... Atf team supporters Pls kindly tell me Where I'm doing wrong |
The Following 3 Users Say Thank You to .::AZEEM::. For This Useful Post: |
07-19-2014, 06:34 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @.::AZEEM::. Your logs show, nothing wrong with eMMC. Download this: i9300_atf_emmc.rar Then write the 3 files 1 by 1 to Appropriate Partition. If you get WRITE ERROR, then possible your eMMC firmware set the chip to "WRITEP ROTECTED". In this case, there is no solution for it. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
07-19-2014, 11:34 | #4 (permalink) | |
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Quote:
Yes Ur right nothing wrong with eMMC . Problem in power IC now my phone working thanks | |
09-09-2014, 20:45 | #10 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | This pinout are FULL WORKING 100%, you connection can be wrong. Please with Box you have? ATF BIG or LIGHT/NITRO?, if have Nitro are using 2 External power adapter or 4 in 1 adapter?, if have BIG Atf are sure that PIN 2 you are using for VCC and VCCQ?, try to solve all these thinghs then after post Full Log with Screenshoot of Error, Br allumts |
11-03-2014, 07:38 | #13 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
Check your Test Point Soldering! CMD1 Reply: 0x1807FC04 i have big atf i have atf adapter i already solder 2 100 ohm register still i get this error | |
11-03-2014, 08:26 | #15 (permalink) |
Member: 160928 Status: Offline Thanks Meter: 338 | r u sure? caz i m trying to connect working phone also i can not connect have look this thread http://forum.gsmhosting.com/vbb/f609...error-1875457/ and with another phone giving me this error i have ATF big box Code: 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x5E5E5E5E i check 3 time test pint is 100% right |
