05-22-2015, 15:12 | #1 (permalink) |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | I9300 EMMC dead Emmc direct pinout EMMC_zps52c37047.jpg Photo by kimberlycanada34 | Photobucket and my atf screen shot I apply this procedure but no success http://forum.gsmhosting.com/vbb/f609...tures-1945278/ B:R |
05-22-2015, 17:45 | #2 (permalink) |
Member: 194907 Status: Offline Thanks Meter: 114 | My problem solved datao pin resolder but not write File Author: ATF Team @ X-Shadow Date Created: 21/02/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KMVTU000LM-B503 eMMC Product Name: VTU00M eMMC Product Rev: 15.7 Preparing eMMC for Firmware Update... ERROR: SET_BLOCK_COUNT FAILED (CMD23) 0x08 Total Elapsed Time 00:00:18 this problem same http://forum.gsmhosting.com/vbb/11021895-post9.html |
05-23-2015, 06:21 | #3 (permalink) |
Member: 194907 Status: Offline Thanks Meter: 114 | here is the log 0:16:42 : ================================================== ==== 20:16:42 : ================================================== ==== 20:16:42 : eMMC Test Point Connection Module 20:16:42 : ================================================== ==== 20:16:42 : ================================================== ==== 20:16:42 : 20:16:42 : 1. DO NOT USE THE PHONE"S BATTERY 20:16:42 : 2. Connect the Soldered TP Connections to ATF Box 20:16:42 : 3. Disconnect the USB Cable and Wait until the 20:16:42 : the ATF Software will tell you to Connect the USB. 20:16:42 : 20:16:42 : 20:16:42 : Interface Reset OK! 20:16:42 : eMMC Access Type: SECTOR MODE 20:16:42 : eMMC Supported Voltage Range: 20:16:42 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 20:16:42 : 20:16:42 : CID : 1501003030303030305620110726589D 20:16:42 : CSD : 902701320F5903FFF6DBFFEF8A404023 20:16:42 : 20:16:42 : eMMC Boot Information 20:16:42 : Revision 1.5 (for MMC v4.41) 20:16:42 : BOOT PARTITION : NOT BOOT ENABLED 20:16:42 : PARTITION ACCESS : R/W USER PARTITION 20:16:42 : PERM_BOOT_CFG_PROT : DISABLED 20:16:42 : PWR_BOOT_CFG_PROT : DISABLED 20:16:42 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 20:16:42 : RESET BUS WIDTH : ENABLED 20:16:42 : eMMC FirmW UPDATE : DISABLED 20:16:42 : EMMC CACHE SIZE : 0 KB 20:16:42 : SUPER PAGE SIZE : 4096 KB 20:16:42 : HC ERASE GROUP SIZE: 512 KB 20:16:42 : USER AREA SIZE : 17179869184 BYTES 20:16:42 : BOOT PARTITION SIZE: 512 KB 20:16:42 : RPMB PARTITION SIZE: 128 KB 20:16:42 : 20:16:42 : 20:16:42 : eMMC Device Information 20:16:42 : Manufacturer ID: SAMSUNG 20:16:42 : Device Type : Embedded BGA 20:16:42 : Application ID : 00 20:16:42 : Product Name : 000000 20:16:42 : Product Rev : 5.6 20:16:42 : Product SN : 20110726 20:16:42 : Manufactured : January 2005 20:16:42 : 20:16:42 : Card Specific Data 20:16:42 : CSD_STRUCTURE : Version 1.2 20:16:42 : SPEC_VERS : Version 4.1/4.2/4.3 20:16:42 : TAAC : 13 ns 20:16:42 : TRAN_SPEED : 4000000 KHz 20:16:42 : READ_BL_LEN : 512 Bytes 20:16:42 : C_SIZE : HIGH CAPACITY 20:16:42 : WP_GRP_ENABLE : YES 20:16:42 : WRITE_BL_LEN : 512 Bytes 20:16:42 : CONTENT_PROT_APP : NO 20:16:42 : PERM_WRITE_PROTECT: NO 20:16:42 : TMP_WRITE_PROTECT : NO 20:16:42 : 20:16:42 : Extended CSD Saved: 20:16:42 : 1501003030303030305620110726589D.ext_csd 20:16:42 : Backup Directory: 20:16:42 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 20:16:42 : 20:16:43 : 20:16:43 : Task Selected: Samsung eMMC Firmware Update 20:16:43 : ================================================== ==== 20:16:43 : --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB 20:16:43 : --> This will RESET EXT_CSD Programming Such as BOOT 20:16:43 : Options, Bus Characteristics and Partition Sizes.. 20:16:43 : ================================================== ==== 20:16:43 : 20:16:43 : Please Manually Select the Correct 20:16:43 : Part Number of your eMMC Device. 20:16:43 : 20:16:43 : ================================================== ==== 20:16:43 : If you select a WRONG PART NUMBER, then 20:16:43 : YOU WILL PROBABLY KILL THE EMMC !!! 20:16:43 : ================================================== ==== 20:17:05 : 20:17:05 : ================================================== ==== 20:17:05 : Loading ATF eMMC Firmware File... (Please Wait) 20:17:05 : ================================================== ==== 20:17:05 : 20:17:05 : 20:17:15 : File Author: ATF Team @ X-Shadow 20:17:15 : Date Created: 21/02/2015 (dd/mm/yyyy) 20:17:15 : Description: Samsung eMMC Firmware 20:17:15 : eMMC Part Number: KMVTU000LM-B503 20:17:15 : eMMC Product Name: VTU00M 20:17:15 : eMMC Product Rev: 15.7 20:17:15 : 20:17:15 : Preparing eMMC for Firmware Update... 20:17:34 : Sending eMMC Firmware Blocks... 20:17:37 : All Blocks Sent! 20:17:37 : NAND Write Delay: 1 Second (Please Wait) 20:17:38 : Verifying eMMC Firmware... 20:17:38 : ERROR: eMMC Firmware Verify FAILED! 20:17:38 : Total Elapsed Time 00:00:22 |
