Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832
Sonork: Faheem Anjum Thanks Meter: 24,310 | i9300 emmc repair ... emmc erase, format , write backup , write user area , write boot 1
all is okay and not face any problem ,
after all when i power on the phone
no product ......
still unable to flash it using multi firmwares+pit
can tell me where is the problem , i am new maybe i do some wrong Quote:
13:53:59 : ================================================
13:53:59 : Advance Turbo Flasher Found
13:53:59 : Driver Version : 00020828
13:53:59 : Library Version : 00030207
13:54:01 : Box Type : AdvanceBox Turbo
13:54:01 : Box Firmware : LogiCore 11.0.00
13:54:01 : Software Version : v11.50
13:54:01 : AdvanceBox SN : B3DEBF8D8CD4D986C16002D6
13:54:01 : Box Status : ACTIVATED
13:54:01 : ================================================
13:54:01 : Box Successfully Initialized
13:54:01 :
13:54:02 : VBATT Powering Down <<<<
13:54:06 : VBATT Powering Up >>>>
13:54:06 : SET VCCIO Level Done
13:54:06 : SET BSI Load Done
13:54:06 :
13:54:06 :
13:54:06 :
13:54:06 : ///////// /// /// /////// /////// /////////
13:54:06 : /// /// /// /// // /// /// /// ///
13:54:06 : /// /// /// /////// /////// /// ///
13:54:06 : /// /// /// /// /// /// /// /// ///
13:54:06 : /// ///// /// /// /////// //////
13:54:06 :
13:54:06 : =======================================
13:54:06 : /// /// /// ///////// /////// //////
13:54:06 : ///// /// /// /// /// // /// ///
13:54:06 : /// ///// /// /// /////// /// ///
13:54:06 : /// //// /// /// /// /// /// ///
13:54:06 : /// /// /// /// /// /// //////
13:54:06 :
13:54:33 : Select a Valid Procedure!
13:54:36 : ================================================== ====
13:54:36 : eMMC Test Point Connection Module
13:54:36 :
13:54:36 : 1. DO NOT USE THE PHONE"S BATTERY
13:54:36 : 2. Connect the Soldered TP Connections to ATF Box
13:54:36 : 3. Disconnect the USB Cable and Wait until the
13:54:36 : the ATF Software will tell you to Connect the USB.
13:54:36 :
13:54:40 : ERROR: EMMC WAS NOT Detected! (CMD1)
13:54:40 : Check your Test Point Soldering!
13:54:40 : CMD1 Reply: 0x00000000
13:54:43 : ================================================== ====
13:54:43 : eMMC Test Point Connection Module
13:54:43 :
13:54:43 : 1. DO NOT USE THE PHONE"S BATTERY
13:54:43 : 2. Connect the Soldered TP Connections to ATF Box
13:54:43 : 3. Disconnect the USB Cable and Wait until the
13:54:43 : the ATF Software will tell you to Connect the USB.
13:54:43 :
13:54:48 : ERROR: EMMC WAS NOT Detected! (CMD1)
13:54:48 : Check your Test Point Soldering!
13:54:48 : CMD1 Reply: 0x00000000
14:01:44 : ================================================== ====
14:01:44 : eMMC Test Point Connection Module
14:01:44 :
14:01:44 : 1. DO NOT USE THE PHONE"S BATTERY
14:01:44 : 2. Connect the Soldered TP Connections to ATF Box
14:01:44 : 3. Disconnect the USB Cable and Wait until the
14:01:44 : the ATF Software will tell you to Connect the USB.
14:01:44 :
14:01:44 :
14:01:44 : Interface Reset OK!
14:01:44 : eMMC Access Type: SECTOR MODE
14:01:44 : eMMC Supported Voltage Range:
14:01:44 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
14:01:44 :
14:01:44 : CID : 15010056545530304DF1304A6344
14:01:44 : CSD : D02701320F5903FFF6DBFFFF8E40406D
14:01:44 :
14:01:44 : eMMC Boot Information
14:01:44 : Revision 1.6 (for MMC v4.5)
14:01:44 : BOOT PARTITION : BOOT PARTITION 1
14:01:44 : PARTITION ACCESS : R/W USER PARTITION
14:01:44 : PERM_BOOT_CFG_PROT : DISABLED
14:01:44 : PWR_BOOT_CFG_PROT : DISABLED
14:01:44 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
14:01:44 : RESET BUS WIDTH : ENABLED
14:01:44 : eMMC FirmW UPDATE : DISABLED
14:01:44 : EMMC CACHE SIZE : 0 KB
14:01:44 : SUPER PAGE SIZE : 3584 KB
14:01:44 : HC ERASE GROUP SIZE: 512 KB
14:01:44 : USER AREA SIZE : 15758000128 BYTES
14:01:44 : BOOT PARTITION SIZE: 4096 KB
14:01:44 : RPMB PARTITION SIZE: 512 KB
14:01:44 :
14:01:44 :
14:01:44 : eMMC Device Information
14:01:44 : Manufacturer ID: SAMSUNG
14:01:44 : Device Type : Embedded BGA
14:01:44 : Application ID : 00
14:01:44 : Product Name : VTU00M
14:01:44 : Product Rev : 15.1
14:01:44 : Product SN : 304A6344
14:01:44 : Manufactured : January 2012
14:01:44 :
14:01:44 : Card Specific Data
14:01:44 : CSD_STRUCTURE : Extended
14:01:44 : SPEC_VERS : Version 4.1/4.2/4.3
14:01:44 : TAAC : 13 ns
14:01:44 : TRANS_SPEED : 4000000 KHz
14:01:44 : READ_BL_LEN : 512 Bytes
14:01:44 : C_SIZE : HIGH CAPACITY
14:01:44 : WP_GRP_ENABLE : YES
14:01:44 : WRITE_BL_LEN : 512 Bytes
14:01:44 : CONTENT_PROT_APP : NO
14:01:44 : PERM_WRITE_PROTECT: NO
14:01:44 : TMP_WRITE_PROTECT : NO
14:01:44 :
14:01:44 : Extended CSD Saved:
14:01:44 : 15010056545530304DF1304A6344_847B3179.ext_csd
14:01:44 : Backup Directory:
14:01:44 : N:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
14:01:44 :
14:08:19 : ================================================== ====
14:08:19 : eMMC Test Point Connection Module
14:08:19 :
14:08:19 : 1. DO NOT USE THE PHONE"S BATTERY
14:08:19 : 2. Connect the Soldered TP Connections to ATF Box
14:08:19 : 3. Disconnect the USB Cable and Wait until the
14:08:19 : the ATF Software will tell you to Connect the USB.
14:08:19 :
14:08:19 :
14:08:19 : Interface Reset OK!
14:08:19 : eMMC Access Type: SECTOR MODE
14:08:19 : eMMC Supported Voltage Range:
14:08:19 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
14:08:19 :
14:08:19 : CID : 15010056545530304DF1304A6344
14:08:19 : CSD : D02701320F5903FFF6DBFFFF8E40406D
14:08:19 :
14:08:19 : eMMC Boot Information
14:08:19 : Revision 1.6 (for MMC v4.5)
14:08:19 : BOOT PARTITION : BOOT PARTITION 1
14:08:19 : PARTITION ACCESS : R/W USER PARTITION
14:08:19 : PERM_BOOT_CFG_PROT : DISABLED
14:08:19 : PWR_BOOT_CFG_PROT : DISABLED
14:08:19 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
14:08:19 : RESET BUS WIDTH : ENABLED
14:08:19 : eMMC FirmW UPDATE : DISABLED
14:08:19 : EMMC CACHE SIZE : 0 KB
14:08:19 : SUPER PAGE SIZE : 3584 KB
14:08:19 : HC ERASE GROUP SIZE: 512 KB
14:08:19 : USER AREA SIZE : 15758000128 BYTES
14:08:19 : BOOT PARTITION SIZE: 4096 KB
14:08:19 : RPMB PARTITION SIZE: 512 KB
14:08:19 :
14:08:19 :
14:08:19 : eMMC Device Information
14:08:19 : Manufacturer ID: SAMSUNG
14:08:19 : Device Type : Embedded BGA
14:08:19 : Application ID : 00
14:08:19 : Product Name : VTU00M
14:08:19 : Product Rev : 15.1
14:08:19 : Product SN : 304A6344
14:08:19 : Manufactured : January 2012
14:08:19 :
14:08:19 : Card Specific Data
14:08:19 : CSD_STRUCTURE : Extended
14:08:19 : SPEC_VERS : Version 4.1/4.2/4.3
14:08:19 : TAAC : 13 ns
14:08:19 : TRANS_SPEED : 4000000 KHz
14:08:19 : READ_BL_LEN : 512 Bytes
14:08:19 : C_SIZE : HIGH CAPACITY
14:08:19 : WP_GRP_ENABLE : YES
14:08:19 : WRITE_BL_LEN : 512 Bytes
14:08:19 : CONTENT_PROT_APP : NO
14:08:19 : PERM_WRITE_PROTECT: NO
14:08:19 : TMP_WRITE_PROTECT : NO
14:08:19 :
14:08:19 : Extended CSD Saved:
14:08:19 : 15010056545530304DF1304A6344_A5DDD8C8.ext_csd
14:08:19 : Backup Directory:
14:08:19 : N:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
14:08:19 :
14:11:28 : ================================================== ====
14:11:28 : eMMC Test Point Connection Module
14:11:28 :
14:11:28 : 1. DO NOT USE THE PHONE"S BATTERY
14:11:28 : 2. Connect the Soldered TP Connections to ATF Box
14:11:28 : 3. Disconnect the USB Cable and Wait until the
14:11:28 : the ATF Software will tell you to Connect the USB.
14:11:28 :
14:11:28 :
14:11:28 : Interface Reset OK!
14:11:28 : eMMC Access Type: SECTOR MODE
14:11:28 : eMMC Supported Voltage Range:
14:11:28 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
14:11:28 :
14:11:28 : CID : 15010056545530304DF1304A6344
14:11:29 : CSD : D02701320F5903FFF6DBFFFF8E40406D
14:11:29 :
14:11:29 : eMMC Boot Information
14:11:29 : Revision 1.6 (for MMC v4.5)
14:11:29 : BOOT PARTITION : BOOT PARTITION 1
14:11:29 : PARTITION ACCESS : R/W USER PARTITION
14:11:29 : PERM_BOOT_CFG_PROT : DISABLED
14:11:29 : PWR_BOOT_CFG_PROT : DISABLED
14:11:29 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
14:11:29 : RESET BUS WIDTH : ENABLED
14:11:29 : eMMC FirmW UPDATE : DISABLED
14:11:29 : EMMC CACHE SIZE : 0 KB
14:11:29 : SUPER PAGE SIZE : 3584 KB
14:11:29 : HC ERASE GROUP SIZE: 512 KB
14:11:29 : USER AREA SIZE : 15758000128 BYTES
14:11:29 : BOOT PARTITION SIZE: 4096 KB
14:11:29 : RPMB PARTITION SIZE: 512 KB
14:11:29 :
14:11:29 :
14:11:29 : eMMC Device Information
14:11:29 : Manufacturer ID: SAMSUNG
14:11:29 : Device Type : Embedded BGA
14:11:29 : Application ID : 00
14:11:29 : Product Name : VTU00M
14:11:29 : Product Rev : 15.1
14:11:29 : Product SN : 304A6344
14:11:29 : Manufactured : January 2012
14:11:29 :
14:11:29 : Card Specific Data
14:11:29 : CSD_STRUCTURE : Extended
14:11:29 : SPEC_VERS : Version 4.1/4.2/4.3
14:11:29 : TAAC : 13 ns
14:11:29 : TRANS_SPEED : 4000000 KHz
14:11:29 : READ_BL_LEN : 512 Bytes
14:11:29 : C_SIZE : HIGH CAPACITY
14:11:29 : WP_GRP_ENABLE : YES
14:11:29 : WRITE_BL_LEN : 512 Bytes
14:11:29 : CONTENT_PROT_APP : NO
14:11:29 : PERM_WRITE_PROTECT: NO
14:11:29 : TMP_WRITE_PROTECT : NO
14:11:29 :
14:11:29 : Extended CSD Saved:
14:11:29 : 15010056545530304DF1304A6344_C3877983.ext_csd
14:11:29 : Backup Directory:
14:11:29 : N:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
14:11:29 :
14:11:32 :
14:11:32 : Task Selected: Normal Factory Erase
14:11:32 : ================================================== ====
14:11:32 : For eMMC Revision 1.2 (for MMC v4.2) and LOWER
14:11:32 : --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB
14:11:32 : For eMMC Revision 1.3 (for MMC v4.3) and HIGHER
14:11:32 : --> This will ONLY ERASE USER AREA
14:11:32 : This eMMC is: Revision 1.6 (for MMC v4.5)
14:11:32 :
14:11:32 : Factory Erasing Supported FLASH AREA...
14:11:33 : Normal Factory Erase Done!
14:11:33 :
14:11:33 : ================================================== ====
14:11:33 : WARNING - WARNING - WARNING - WARNING - WARNING
14:11:33 : 1. WRITE BOOT1 Image if Needed
14:11:33 : 2. WRITE BOOT2 Image if Needed
14:11:33 : 3. WRITE USER AREA Image if Needed
14:12:13 : ================================================== ====
14:12:13 : eMMC Test Point Connection Module
14:12:13 :
14:12:13 : 1. DO NOT USE THE PHONE"S BATTERY
14:12:13 : 2. Connect the Soldered TP Connections to ATF Box
14:12:13 : 3. Disconnect the USB Cable and Wait until the
14:12:13 : the ATF Software will tell you to Connect the USB.
14:12:13 :
14:12:13 :
14:12:13 : Interface Reset OK!
14:12:13 : eMMC Access Type: SECTOR MODE
14:12:13 : eMMC Supported Voltage Range:
14:12:13 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
14:12:13 :
14:12:13 : CID : 15010056545530304DF1304A6344
14:12:13 : CSD : D02701320F5903FFF6DBFFFF8E40406D
14:12:13 :
14:12:13 : eMMC Boot Information
14:12:13 : Revision 1.6 (for MMC v4.5)
14:12:13 : BOOT PARTITION : BOOT PARTITION 1
14:12:13 : PARTITION ACCESS : R/W USER PARTITION
14:12:13 : PERM_BOOT_CFG_PROT : DISABLED
14:12:13 : PWR_BOOT_CFG_PROT : DISABLED
14:12:13 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
14:12:13 : RESET BUS WIDTH : ENABLED
14:12:13 : eMMC FirmW UPDATE : DISABLED
14:12:13 : EMMC CACHE SIZE : 0 KB
14:12:13 : SUPER PAGE SIZE : 3584 KB
14:12:13 : HC ERASE GROUP SIZE: 512 KB
14:12:13 : USER AREA SIZE : 15758000128 BYTES
14:12:13 : BOOT PARTITION SIZE: 4096 KB
14:12:13 : RPMB PARTITION SIZE: 512 KB
14:12:13 :
14:12:13 :
14:12:13 : eMMC Device Information
14:12:13 : Manufacturer ID: SAMSUNG
14:12:13 : Device Type : Embedded BGA
14:12:13 : Application ID : 00
14:12:13 : Product Name : VTU00M
14:12:13 : Product Rev : 15.1
14:12:13 : Product SN : 304A6344
14:12:13 : Manufactured : January 2012
14:12:13 :
14:12:13 : Card Specific Data
14:12:13 : CSD_STRUCTURE : Extended
14:12:13 : SPEC_VERS : Version 4.1/4.2/4.3
14:12:13 : TAAC : 13 ns
14:12:13 : TRANS_SPEED : 4000000 KHz
14:12:13 : READ_BL_LEN : 512 Bytes
14:12:13 : C_SIZE : HIGH CAPACITY
14:12:13 : WP_GRP_ENABLE : YES
14:12:13 : WRITE_BL_LEN : 512 Bytes
14:12:13 : CONTENT_PROT_APP : NO
14:12:13 : PERM_WRITE_PROTECT: NO
14:12:13 : TMP_WRITE_PROTECT : NO
14:12:13 :
14:12:13 : Extended CSD Saved:
14:12:13 : 15010056545530304DF1304A6344_AFD64642.ext_csd
14:12:13 : Backup Directory:
14:12:13 : N:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
14:12:13 :
14:12:15 :
14:12:15 : Task Selected: Samsung Factory Format
14:12:15 : ================================================== ====
14:12:15 : For eMMC Revision 1.5 (for MMC v4.41) and LOWER
14:12:15 : --> This will ERASE USER AREA, BOOT1, BOOT2, RPMB and EXT_CSD R/W/E Entries
14:12:15 : For eMMC Revision 1.6 (for MMC v4.5) and HIGHER
14:12:15 : --> This will ONLY ERASE USER AREA
14:12:15 : This eMMC is: Revision 1.6 (for MMC v4.5)
14:12:15 :
14:12:15 : Samsung Factory Format Start...
14:12:16 : Format Done!
14:12:16 :
14:12:16 : ================================================== ====
14:12:16 : WARNING - WARNING - WARNING - WARNING - WARNING
14:12:16 : 1. WRITE Back EXT_CSD Backup if Needed
14:12:16 : 2. WRITE BOOT1 Image if Needed
14:12:16 : 3. WRITE BOOT2 Image if Needed
14:12:16 : 4. WRITE USER AREA Image if Needed
14:12:54 : ================================================== ====
14:12:54 : eMMC Test Point Connection Module
14:12:54 :
14:12:54 : 1. DO NOT USE THE PHONE"S BATTERY
14:12:54 : 2. Connect the Soldered TP Connections to ATF Box
14:12:54 : 3. Disconnect the USB Cable and Wait until the
14:12:54 : the ATF Software will tell you to Connect the USB.
14:12:54 :
14:12:55 :
14:12:55 : Interface Reset OK!
14:12:55 : eMMC Access Type: SECTOR MODE
14:12:55 : eMMC Supported Voltage Range:
14:12:55 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
14:12:55 :
14:12:55 : CID : 15010056545530304DF1304A6344
14:12:55 : CSD : D02701320F5903FFF6DBFFFF8E40406D
14:12:55 :
14:12:55 : eMMC Boot Information
14:12:55 : Revision 1.6 (for MMC v4.5)
14:12:55 : BOOT PARTITION : BOOT PARTITION 1
14:12:55 : PARTITION ACCESS : R/W USER PARTITION
14:12:55 : PERM_BOOT_CFG_PROT : DISABLED
14:12:55 : PWR_BOOT_CFG_PROT : DISABLED
14:12:55 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
14:12:55 : RESET BUS WIDTH : ENABLED
14:12:55 : eMMC FirmW UPDATE : DISABLED
14:12:55 : EMMC CACHE SIZE : 0 KB
14:12:55 : SUPER PAGE SIZE : 3584 KB
14:12:55 : HC ERASE GROUP SIZE: 512 KB
14:12:55 : USER AREA SIZE : 15758000128 BYTES
14:12:55 : BOOT PARTITION SIZE: 4096 KB
14:12:55 : RPMB PARTITION SIZE: 512 KB
14:12:55 :
14:12:55 :
14:12:55 : eMMC Device Information
14:12:55 : Manufacturer ID: SAMSUNG
14:12:55 : Device Type : Embedded BGA
14:12:55 : Application ID : 00
14:12:55 : Product Name : VTU00M
14:12:55 : Product Rev : 15.1
14:12:55 : Product SN : 304A6344
14:12:55 : Manufactured : January 2012
14:12:55 :
14:12:55 : Card Specific Data
14:12:55 : CSD_STRUCTURE : Extended
14:12:55 : SPEC_VERS : Version 4.1/4.2/4.3
14:12:55 : TAAC : 13 ns
14:12:55 : TRANS_SPEED : 4000000 KHz
14:12:55 : READ_BL_LEN : 512 Bytes
14:12:55 : C_SIZE : HIGH CAPACITY
14:12:55 : WP_GRP_ENABLE : YES
14:12:55 : WRITE_BL_LEN : 512 Bytes
14:12:55 : CONTENT_PROT_APP : NO
14:12:55 : PERM_WRITE_PROTECT: NO
14:12:55 : TMP_WRITE_PROTECT : NO
14:12:55 :
14:12:55 : Extended CSD Saved:
14:12:55 : 15010056545530304DF1304A6344_00A182AF.ext_csd
14:12:55 : Backup Directory:
14:12:55 : N:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
14:12:55 :
14:13:17 :
14:13:17 : Task Selected: Write EXT_CSD Backup
14:13:17 : Task Done!
14:13:17 :
14:14:42 : Start Writing 0x001EC209 Blocks at 0x00000000
14:14:42 : Partition Selected: USER AREA
14:47:22 :
14:47:22 : Total Elapsed Time 00:32:40
14:47:22 : Write Success!
14:55:39 : Start Writing 0x00001000 Blocks at 0x00000000
14:55:39 : Partition Selected: BOOT 1
14:55:43 :
14:55:43 : Total Elapsed Time 00:00:03
14:55:43 : Write Success!
14:56:14 : ================================================== ====
14:56:14 : eMMC Test Point Connection Module
14:56:14 :
14:56:14 : 1. DO NOT USE THE PHONE"S BATTERY
14:56:14 : 2. Connect the Soldered TP Connections to ATF Box
14:56:14 : 3. Disconnect the USB Cable and Wait until the
14:56:14 : the ATF Software will tell you to Connect the USB.
14:56:14 :
14:56:15 :
14:56:15 : Interface Reset OK!
14:56:15 : eMMC Access Type: SECTOR MODE
14:56:15 : eMMC Supported Voltage Range:
14:56:15 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
14:56:15 :
14:56:15 : CID : 15010056545530304DF1304A6344
14:56:15 : CSD : D02701320F5903FFF6DBFFFF8E40406D
14:56:15 :
14:56:15 : eMMC Boot Information
14:56:15 : Revision 1.6 (for MMC v4.5)
14:56:15 : BOOT PARTITION : BOOT PARTITION 1
14:56:15 : PARTITION ACCESS : R/W USER PARTITION
14:56:15 : PERM_BOOT_CFG_PROT : DISABLED
14:56:15 : PWR_BOOT_CFG_PROT : DISABLED
14:56:15 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
14:56:15 : RESET BUS WIDTH : ENABLED
14:56:15 : eMMC FirmW UPDATE : DISABLED
14:56:15 : EMMC CACHE SIZE : 0 KB
14:56:15 : SUPER PAGE SIZE : 3584 KB
14:56:15 : HC ERASE GROUP SIZE: 512 KB
14:56:15 : USER AREA SIZE : 15758000128 BYTES
14:56:15 : BOOT PARTITION SIZE: 4096 KB
14:56:15 : RPMB PARTITION SIZE: 512 KB
14:56:15 :
14:56:15 :
14:56:15 : eMMC Device Information
14:56:15 : Manufacturer ID: SAMSUNG
14:56:15 : Device Type : Embedded BGA
14:56:15 : Application ID : 00
14:56:15 : Product Name : VTU00M
14:56:15 : Product Rev : 15.1
14:56:15 : Product SN : 304A6344
14:56:15 : Manufactured : January 2012
14:56:15 :
14:56:15 : Card Specific Data
14:56:15 : CSD_STRUCTURE : Extended
14:56:15 : SPEC_VERS : Version 4.1/4.2/4.3
14:56:15 : TAAC : 13 ns
14:56:15 : TRANS_SPEED : 4000000 KHz
14:56:15 : READ_BL_LEN : 512 Bytes
14:56:15 : C_SIZE : HIGH CAPACITY
14:56:15 : WP_GRP_ENABLE : YES
14:56:15 : WRITE_BL_LEN : 512 Bytes
14:56:15 : CONTENT_PROT_APP : NO
14:56:15 : PERM_WRITE_PROTECT: NO
14:56:15 : TMP_WRITE_PROTECT : NO
14:56:15 :
14:56:15 : Extended CSD Saved:
14:56:15 : 15010056545530304DF1304A6344_09325FD4.ext_csd
14:56:15 : Backup Directory:
14:56:15 : N:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
