11-08-2014, 09:03 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | i9305 Test Point Location A and B need ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x03 Application ID : SD Product Name : SU16G Product Revision : 8.0 Serial Number : 8129D52E Manufacture Date: April 2011 Card CID: 0353445355313647808129D52E00B4A9 Card CSD: 400E00325B59000076B27F800A404013 Card SCR: 0235800100000000 Card OCR: 00C0FF8000 SD Card Size : 15931539456 Bytes SD Block Size: 512 Bytes Maximum Speed: 25000000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is NOT Password Protected!!! Erasing SDC... Samsung GT-I9305 UNBRICK 4.3 Start Writing to SDC at 0x00000000... Number of Blocks: 0x00001000 Process Done... ================================================== ==== 1. Solder THIN WIRE to Test Point Location A and B 2. Connect Test Point A and B Together 3. Assemble Phone with LCD 4. Make Sure Battery is Fully Charged 5. Press Power Button and Wait for SDCARD MODE Menu 6. Press Volume DOWN KEY to Enter DOWNLOAD MODE 7. DISCONNECT Test Point A and B Connection 8. Flash the Phone with ODIN ================================================== ==== Total Elapsed Time 00:00:10 Write Success! |
05-16-2015, 05:42 | #6 (permalink) | |
No Life Poster Join Date: Nov 2013 Location: Third World ;)
Member: 2061381 Status: Offline Sonork: 100.1673769 Thanks Meter: 129 | Quote:
You need to find "CMD" and "VCCQ" points, and there you have A and B TP. Greetings. BR | |
05-19-2015, 11:47 | #7 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Ireland
Member: 117145 Status: Offline Sonork: 1617520 Thanks Meter: 382 | Quote:
