07-08-2014, 12:54 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1757924 Status: Offline Sonork: 100.1675762 Thanks Meter: 40 | I9500 Direct Emmc HELP - (PINOUT INSIDE) I think damaged EMMC how can I repair using ATF Direct Emmc I have activated ATF Jtag |
07-08-2014, 14:50 | #2 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Venezuela
Member: 2141947 Status: Offline Thanks Meter: 17 | Repair emmc direct... Friends of atf team which is the mystery of not publishing tutorials works exactly like the atf repairing emmc directly on the plate in the tlf supported there is no clear explanation of how to do it yet, or at least are several members of this forum that no very clearly how it works we are thanked a more complete support with this thank you very much ... |
07-09-2014, 04:00 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @hakan 3 First Try if you can still connect to eMMC... Then select BOOT1 file according to Android Version you think is inside your phone. http://www.4shared.com/download/1yAo....rar?lgfp=3000 Have 4.2.2, 4.3 and 4.4.2 inside... All you need is BOOT1, then it will be enough to make phone enter into Download Mode and flash. Post logs of eMMC Scan. Last edited by Advance-Box; 07-09-2014 at 04:33. |
07-10-2014, 00:10 | #6 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Just one question staff. The VCC and VCCq voltages are respectively 3.3 v and 1.8 v on other boxes, this photo and others you used 3.0 v to the same voltages. This is applicable to other EMMC, use the same voltage to the VCC and VCCq? Do not run the risk of damaging the EMMC? |
07-10-2014, 01:15 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Emmc specifications allows VccQ and Vcc to work properly on a common 2.80v or 3.30v power source. Just make sure you will use those 100 ohms pull-ups otherwise it will not work. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
