12-03-2014, 06:55 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Philippines
Member: 1494304 Status: Offline Sonork: 100.1606186 Thanks Meter: 108 | i9505 no power! help! status: no power, no usb connection like qualcom history: after charging cant power rps reading: in screen shot action taken 1. try to sdc repair, no boot after inserting mmc with autoboot connector 2. try to jtag using atf adaptor, shift IR error 3. try to use shorter wire, still shift IR error 4. try to use rj45 cable but still shift IR error 5. sometimes connects but sometimes it shows disconnect heres the screen shot from atf jtag software and rps reading additonal question how can we distinguish deadboot that can repair by software or jtag to a deadboot which cannot be repair by software, or in short we can say that it hardware failure? thanks in advance Last edited by warshock; 12-03-2014 at 07:01. |
12-03-2014, 08:10 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @warshock If your phone is NOT detected in Device Manager as VID_05C6&PIN_9008, then I would say it is not entirely a software problem. I can try teamviewer if you have time. B.R> |
12-03-2014, 09:39 | #4 (permalink) |
Member: 1494304 Status: Offline Sonork: 100.1606186 Thanks Meter: 108 | thanks sir x-shadow sa time if i use emmc pinout, the process is stil like jtag? just load fw, connect and restore boot or i will do other procedure? |
