11-10-2015, 00:15 | #1 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | IMPORTANT: I9300 dead easy repaired "sdc+tp", sometime are lucky!! A) CREATE SD CARD by SDC FILE, HERE: B) PROCEDURE WITH TP SHORTED, STEPS: Quote:
D) AFTER PHONE IS ENTERED IN "DOWNLOAD MODE", (ceck with Usb Cable Phone>PC Windows Sound), HAVE CUT THE 2 WIRES AND FLASHED WITH 4 PART FILE+PIT<<<<<IMPORTANT E) PHONE WAS "UNBRICKED BUT "EFS" and "IMEI+SERIAL" NOT GOOD, AFTER REPAIRED EFS WITH "OCTOPUS", (can use any Box or FREE Efs), IMEI IS TO "DEFAULT", SO LET'S GO FOR REPAIR ALL, HERE: 1) 2) I9300 TURN BACK WORKING PERFECT, NO NETWORK ISSUE, (Imei is Original), ANY OTHER PROBLEM, FULL SUCCESS and TIME SPENT ONLY 30/40MIN.S....BECOUSE WAS ALONE!!! NOTE: Not All are Reparable Fast with this Procedure, if you EMMC is damaged must need of use "EMMC DIRECT TP" also for EMMC TOTALLY DEAD via "NAND_RE#TP to GND", with ATF, or if Not are good REPLACE this. BR allumts | |
The Following 5 Users Say Thank You to allumts For This Useful Post: |
11-10-2015, 11:53 | #4 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Nothing of share if read carefully detailed procedure. Instead of use Twizer i've soldered 2 enamelled copper wires in the TP pinout (CMD) and and united together creating "Short". When phone entered in D.Mode cut this short, remove Card and Flash Full Flash 4 part + PIT...itc... Same Procedure can use ALL with G7102, worked 100% with Good Sdc file created BR allumts Last edited by allumts; 11-10-2015 at 11:59. |
11-11-2015, 12:21 | #7 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | For all that continue writing that "Samsung G7102" cannot repair...have couple of issue itc... I've done one of this (is the 20/30° that repair easy), only with this Same procedure for I9300 above, only Important thing is that the Phone after Flash have all Right Imei, BB, Serial itc... only have Short CMD point (Blu point) resistor, carefully with Twizzer if use these ask help to other person. If Damage the Resistor, can Replace this win any other from other old phone, use mulimetr and when find 10K it's Right. Please who non know this field not try with these procedure becouse damage Only the phone. BR allumts |
11-20-2015, 06:36 | #8 (permalink) |
Registered User Join Date: Dec 2004 Location: largest democratic country
Member: 100376 Status: Offline Sonork: 100.1591842 Thanks Meter: 150 | @allumts plz clearfy which capacity sd card must be used with i9300? as i know with g7102 i have to use 8gb sd card |
11-27-2015, 10:24 | #10 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @malka4u Quote:
Read Stichy thread for I9300/N7100 with NAND TP to GND it's get good hel you for understand procedure. BR allumts | |
