Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-26-2013, 14:40   #16 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 602
Originally Posted by smtel View Post
Advance-box, please, make more accurate photo for modification board of "nitro" - it is difficult to sort soldering places.
After this modification all other function, working over RJ-45 will be ok?
Modification will not affect anything... Because on ATF Nitro and ATF Lightning, PIN2 of RJ-45 is not connected to anything on the PCB.
In picture, you will see Resistor which I soldered wire, and other end of wire is soldered to PIN2 of RJ-45. So that is the main idea...just connect PIN2 to that Resistor using a wire.
This will give you 1.80v or 2.80v or 3.30v on PIN2, depending on VCCIO setting you put inside ATF 10.20 eMMC Tool.
By default, 2.80v work on all eMMC which is used on current mobile phones.
Old 09-26-2013, 14:43   #17 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 602
@remark
Give suggestions on what you want.
Raw address and block address selection can be done easy.
To enable power on PIN2, need to set VPP in settings. Anyway,
I will auto synch it with VCCIO selected next time.
I will release some test exe tomorrow.
About write speed, now is not yet optimized. Only read is very fast, 100mb per minute.
If many interest in this tool, the write speed will also be improved via some special ATF firmware.
The Following 3 Users Say Thank You to X-Shadow For This Useful Post:
Old 09-26-2013, 16:08   #18 (permalink)
Member: 61359
Thanks Meter: 24
@X-Shadow
Yes, reading KMSJS000KM 128MB per 1min 20sec.
Very fast.
If writing will 128MB per 3min, it will be possible to use for writing big images.
I have interest in this tool.
I have Z3X Jtag, but there also small speed direct eMMC.
I think, ATF hardware will greatly increase write speed.
Old 09-27-2013, 17:39   #19 (permalink)
..::Thanh_gsm::..'s Avatar
Member: 207400
Sonork: 100.1582556
Thanks Meter: 262
Hi,
I wonder if I read full emmc dump from good phone and write into other phone, will it damage Simlock, IMEI v.v....?
And if can, all lumia phone can do this way or there will be different between WP7 and WP8.
I met some Lumia 900 just hang on logo and want to try wr full dump from good phone into him.
Old 09-28-2013, 21:49   #20 (permalink)
Member: 2026244
Thanks Meter: 15
Originally Posted by ..::Thanh_gsm::.. View Post
Hi,
Make that 2 of us
Old 09-30-2013, 09:07   #21 (permalink)
Member: 307482
mantappppp atf boxxx keep updatee brooo
Old 10-08-2013, 00:18   #22 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
i try 3 good chip not see ı think need VDD ?
The Following User Says Thank You to BesTCooL For This Useful Post:
Old 10-08-2013, 00:24   #23 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
always this error
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
ERROR: Phone WAS NOT Detected! (CMD1)
Check your Test Point Soldering!
http://img17.imageshack.us/img17/1609/t6np.jpg
Old 10-08-2013, 06:00   #24 (permalink)
Member: 61359
Thanks Meter: 24
Of course, Vdd is needed.
I applying Vdd 1.8V and Vddf 2.8V, although some say that Vdd and Vddf can both 2.8V.
The Following User Says Thank You to remark For This Useful Post:
Old 10-08-2013, 14:08   #25 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
RJ45 pin 2 dont give 2.8 ? u use 2 external power ?
Old 10-08-2013, 14:12   #26 (permalink)
Member: 61359
Thanks Meter: 24
I used 1.8 & 2.8 external power.
Old 10-08-2013, 15:09   #27 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
understand bro thx..
Old 10-08-2013, 20:01   #28 (permalink)
Member: 351566
Thanks Meter: 49
always this error
I wish success to the pride of turkey
Old 10-10-2013, 08:02   #29 (permalink)
Member: 1992115
i have this error
i use only voltage from pin2 , any other voltage need too????
or only
cmd
clk
data0
gns
vddf
need????
Old 10-17-2013, 07:19   #30 (permalink)
Member: 48933
Thanks Meter: 104
can i use this tool to read full eMMC chip to extract content (pictures,etc)
wbr,A
Page generated in 0.23945 seconds with 10 queries
