05-06-2014, 16:06 | #76 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 695166 Status: Offline Thanks Meter: 24 | 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x00000000 what problem this? please help |
05-06-2014, 16:07 | #77 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
But What YOU Wanna DO and which is this exinos phone?... please read udtate from atf in sticky thread about Exinos and Qualcomm cpu samsung...or EXPLAIN clear here what you want do... | |
The Following User Says Thank You to allumts For This Useful Post: |
05-06-2014, 16:19 | #78 (permalink) |
Member: 695166 Status: Offline Thanks Meter: 24 | thank for understand, 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x00000000 any emmc direct connect reply get this error, what this problem i check every connection ok |
05-06-2014, 16:29 | #79 (permalink) | |
Member: 695166 Status: Offline Thanks Meter: 24 | Quote:
what problem with atf | |
05-06-2014, 19:51 | #80 (permalink) | ||
allumts | ||
05-08-2014, 18:49 | #81 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2063160 Status: Offline Sonork: meu Thanks Meter: 0 | about adptador 4x1 attention atf administrator but please post info on cable 4x1 such as where where welding must be connected because I am only seeing pictures of making direct rj45, must be directed to adptador 4x1 grateful |
05-09-2014, 10:31 | #82 (permalink) | |
if you read good there are posted All type of connection allowed, not only Rj45, use Search button, loock First Photo for modified adapter here: http://forum.gsmhosting.com/vbb/f609...epair-1785442/ Or http://forum.gsmhosting.com/vbb/f609...nokia-1763485/ Br allumts | |
05-16-2014, 19:06 | #83 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote:
N7100_ATF4IN1_V2.jpg hosted at GSMImagehost - GSM Community image sharing ATF_EA_V2_BOOT_1_OK.jpg hosted at GSMImagehost - GSM Community image sharing ATF_EA_V2_BOOT_2_OK.jpg hosted at GSMImagehost - GSM Community image sharing ATF_EA_V2_USER_DATA_OK.jpg hosted at GSMImagehost - GSM Community image sharing ATF_EMMC_Normal_factory_Erase.jpg hosted at GSMImagehost - GSM Community image sharing ATFEMMC.jpg hosted at GSMImagehost - GSM Community image sharing ATF EMMC JTAG Ulitmate All In 1 Adaptor Detect Phone Normal Factory Erase Write User Data Write Boot 1 Write Boot 2 | |
07-16-2014, 14:44 | #84 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2206567 Status: Offline Thanks Meter: 0 | Hi, is it possible to access the user area on the chip and read all data? I know this is not the correct thread, but it seems that here are all the people with the needed knowledge I've a bricked Samsung galaxy Note 2 and it's only booting in ODIN but won't write flash. Also no ProductName on Odin- Screen. I want to unsolder the Chip and connect it to a SD- Card Reader. Is this the right way to access the Files? The Phone is not so important; need the Photos and adressbook... Than the phone can move to the trash Please help! regards from Germany Marcel |
07-16-2014, 17:22 | #85 (permalink) | |
If just you not have Product Name, must need of to try to restore with eMMc Direct Connection, (cpu in board or out is the same), but first of all you have need of Format and Erase for write after all partition, so, when you Erase/Format have lost any data in this eMMc. Other thingh, over 10 device only 2 can restore the other 8 have need to replace eMMc. With Atf and eMMc damaged you cannot restore "User Data", Br allumts | |
07-17-2014, 14:21 | #86 (permalink) |
Member: 2206567 Status: Offline Thanks Meter: 0 | another solution Hi, that is very sad Found some geeks who connected their Nintendo 3DS with eMMC directly to a SD- Card adapter and where able to read and write on the Chip. And the eMMC was still soldered in.. So I gave the Galaxy Note a last chance: I've connected GND,CMD, D0 and CLK (on PCB) to an SD- Adapter and tryed to read the eMMC with a cardreader. For this to work The Mobile must be on to power the eMMC and there is the next problem. The Nintendo is sending CLK and CMD to the eMMC but when another CLK line is already connected the nintendo'll stop sending signals to the chip and that is the trick... I've used a logic analyzer to monitor these Data- Lines but my Cardreader won't send CLK so I need to find anoter SD- cardreader. Maybe the eMMC isn't fully broken; only the bootsektor maybe? regards Marcel |
07-17-2014, 14:40 | #87 (permalink) |
No Life Poster Join Date: Jan 2004 Location: SLOVENIA, LJUBLJANA Age: 55
Member: 48933 Status: Offline Thanks Meter: 104 | o try to restore with eMMc Direct Connection, (cpu in board or out is the same), With Atf and eMMc damaged you cannot restore "User Data", Br allumts[/QUOTE] how about if eMMC chip is OK , only board/phone is damaged? wbr,A |
07-17-2014, 17:31 | #88 (permalink) | |
New Feature in ATF 10.20 is an option in ATF Plus --> eMMC Tool 2.0 that allows you to READ/WRITE eMMC Chips that are not connected to the Phone's PCB. Link: INFO: eMMC ADAPTER (Direct Connection) Br allumts | |
09-10-2014, 08:00 | #90 (permalink) | |
For to be sure by 4 in 1 adapter and solve anythinghs, link in Sticky Thread, Br allumts | |
