02-04-2014, 12:24 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | ((((((((((( install new nokia driver for xg221 - asha 500 )))))))))))))))))))))) You need to install new Nokia Connectivity Drivers for the Latest Phones... Find it here: C:\AdvanceBox Turbo Flasher\Driver\Nokia_Connectivity_Cable_Driver_7.1.182.0.msi B.R. |
02-04-2014, 12:26 | #2 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL Here is Asha 500 DS RM-934 Buscheck after installing Latest Nokia Connectivity Drivers: Code: Booting Phone via USB... ====================================================== ====================================================== USB Phone BUSCheck Boot ====================================================== ====================================================== Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Infineon Boot: F016194200021C030101CA921109A226CC38A9C5FE00FFFF CPU Type: Intel XG221 Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Boot Successful... Unique Data: CA921109A226CC38 Original Product Code: 059V571 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\358355053243362\358355053243362_72505.rpl Infineon USB Buscheck Done Phone Restart Mode: TEST MODE Process Done... Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 13.0.6 20-11-13 RM-934 (c) Nokia IMEI Plain : 358355053243362 IMEI Spare : A358355053243360 IMEI SV : 33583550532433602F IMEI (2nd) : 358355053243370 IMEI Spare : A358355053243370 IMEI SV : 33583550532433702F Phone Model: 6 500 Category : Classic Phone Phone Type : RM-934 ================================================ Extended Phone Information ================================================ Product Serial Number: 42DCC45BH Product Code : 059V571 Module Code : 0205546 Basic Production Code: 059R4P6 Long Production SN : 0 PPM SW Version : c3769ee6a877d53b536a1c6b3c684525bf99ee2d BT MCM Version : 0101-0.1.8 AEM Version : 4336b2-5.92.195.36 MCU SW Version : V 13.0.6 20-11-13 RM-934 (c) Nokia HW Version : 1100 UPP Version : MFR:0xff,DEV:0xff1a,REV:0x11 RFIC Version : Integrated to main ASIC LCD Version : TPO AHNE Version : 12 Variant Version : 0000000000000000000000000000000000000000 TAHVO Version : RM-934-13.0.6-059V571-13.0.1-13.0.1 Wireless LAN ID : CC:89:FD:63:95:73 Bluetooth ID : CC:89:FD:60:88:33 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : P PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 115B6002 DCC Ver: 006008 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... |
03-30-2014, 10:44 | #5 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Philippines Age: 34
Member: 1352605 Status: Offline Thanks Meter: 45 | download here: Nokia_Connectivity_Cable_Driver_7.1.182.0 - Download - 4shared - Anthony Arellano or download ATF_v11.10_Full_Installer here: atf_v11.10_full_installer - Download - 4shared - Linus Hernandez |
01-02-2015, 20:39 | #6 (permalink) |
Insane Poster Join Date: Feb 2011 Location: INDIA NAINITAL
Member: 1519304 Status: Offline Thanks Meter: 42 | NOKIA 500 USB DRIVER DOWNLOAD 32 bit 64 bit Nokia Asha 500 USB Driver For Windows 7 / Xp / 8 32Bit 64Bit Download Mediafire ~ The Mobile Solution And Software Update |
The Following User Says Thank You to filesupplier For This Useful Post: |
